any updates on this??
BB6 Dash swap
Originally posted by Brandoncb7 View PostI was just wondering the same thing Chris lol. He's keeping us in suspense.
Originally posted by pwrusr View PostMy best guess is one of two things happened, he has a case of "Life" or he's wrapping up the finishing touches with this project
Originally posted by F22HB View PostYou are awesome.
Originally posted by ikayto View Postwhem put his car away for winter, project is probably on hold till it's not below zero :]
Originally posted by reccakun08 View Postdude mad props for all the hard work. keep it up!
Thanks for checking back on my thread guys! I appreciate all the support and motivation it gives me.
Originally posted by jokerxfn View Postvery nice! I can always look to fellow cb7tuners for inspirations.
Question: Could you tell tell me what paint you used for the door handles. i'm having trouble getting mine to stick. and also, is there a need to clear coat any interior plastic pieces?
Originally posted by wherm View PostWell, first I soaked the chrome piece in bleach. It takes a while, but gets the chrome off. After that, I sanded it down with 240 grit to make it smooth. Then I used a red 3M scotchbrite pad to scuff it down, same with the plastic trim piece. Scuffing is a very important part of ensuring that the paint sticks. Once it's scuffed, use a degreaser to clean it well. Then spray on a coat of primer, followed by your color of choice. Flat black is what I used. If you spray on multiple (like 6 or 7) light coats, spraying from a distance of 8 inches or so, you'll get that grainy textured look that looks more OEM than just laying on one or two heavy coats. The final key is letting it fully cure for at least a day before putting it back together and using it. You don't need to clearcoat your parts, especially if you're using spray cans since it's not catalyzed anyway. But, if you want that added protection you can do it. There is also a decent selection of regular clear, matte clear, or flat clear to help you acheive the final look that you want.
