SUSP: Front Sway Endlink replacement
    Originally posted by xkjnboix View Post
    ehhh not really i mean if thats all u really need replaced 15-20 is very reasonable. i just stumbled upon a really good deal
    konig52r: i didnt buy them at autozone. im just saying that they are available there for other members who dont know or want to do this.
    O ok I thought you bought the end links at autozone. so where did you get your master kit?
    The past, is history:The future, is a mystery:The present, is a gift.
    James 4:7
    Submit yourself to God. Resist the devil and he will flee from you.
      1st post edited. please read
      [COLOR="Magenta"]
        Originally posted by Juan4DCB7 View Post
        did this install a while back and it is one of those mods that you can actually feel the difference with. I donno if it really helps you much except for ride quality, but bushings are a good upgrade.
        Been saying this for a long time. When people look to upgrade their suspensions, they should first make sure that these endlinks front and rear are in check. They make a big difference in steering response.
        Also, I don't see any reason to replace with OEM, but upgrade to poly as they will last longer. OEMs will eventually dry rot and break apart.
        I agree with only tightening the endlinks by hand until you can not rotate any of the washers inbetween. Another tip is to lubricate the entire length of the long thru-bolt with anti-seize so that you can take these apart in the future. Over time in corrosive environments the spacers, thru-bolt and washers seize to one another and need to be cut off.
          Originally posted by JDMcb792 View Post
          I have this problem with front sway bushing end. Mine was all tear up in pieces after I lower my car it was making werid noises everytime I turn left & drive. How much does it cost? at autozone.
          u should spend 15-20 $ autozone just for the front left and right endlinks. this covered thoroughly throughout the thread
          [COLOR="Magenta"]
            if u guys have an O'Rielly's near by they sell a poly bushing kit for ten bucks... i did it to mine and steering response is way better then oem, the kit only comes with bushings thoe.
            clicky the siggy!!!
            ARCADIA GREEN MEMBER #20
            AIM=SleepygreenCB7
            Yahoo=annamaineeak@yahoo.com
              the kit at auto comes with everything i have pictured if im not mistaken.
              [COLOR="Magenta"]
                Beware that people who live in corrosive environments, this idea will not work as you have to cut off the end-links most of the time. Therefore, buy the Prothane or Energy Suspension poly end-link kits which are like $20 I believe.
                  22.35 shipped
                    glad to c people are using this haha
                    [COLOR="Magenta"]
                      good write up, i'm buying the energy suspension end links to use when i install my EX front sway bar.
                      Current 2016 Ford F150 XLT Sport
                      Past 1990 Accord EX Sedan
                      Past 1990 Accord LX Sedan
                      Past 1991 Accord LX Sedan
                      Past 1993 Accord LX Wagon
                      Current 1991 Accord EX Wagon
                        Mine is seized on somehow....I banged the shit out of it and still no luck..
                          Good write up. I did mine yesterday in about 45 min.
                          2013 Honda Fit Sport Alabaster Silver Metallic GE8
                          2013 Accord Sport Modern Steel Metallic CR2
                          CB9 http://www.cb7tuner.com/vbb/showthre...hlight=hostile
                          CR2 http://www.cb7tuner.com/vbb/showthread.php?t=197787
                          GE8 http://www.cb7tuner.com/vbb/showthread.php?t=199289
                            Good info here.
                            Just one question......can this be done while the car is on all 4 wheels.....or do I have to have it on jackstands.
                            1992 Accord Coupe 5-Speed
                              Originally posted by Shehzada View Post
                              Good info here.
                              Jack stands.
                              Mine was on there pretty bad so I had to have them cut off...good luck.
                                Thank you.
