View Post
How to Bypass Clutch Dampener?
Originally posted by Granite CB7 View PostDef. on the right track! To add in the OEM hardline plus mod it is a fair amount of work (esp w/ the engine in the car!), so the full flexline is very quick and convenient. Shifter cable bushings are the bushings that go into the circular cable ends of the manual shifter cables. The honda ones are rubber, they do a decent job but the aftermarket ones are usually aluminum but can also be brass, delrin, etc. They will yield a more solid and precise shifter feel. If you ever go that route I would HIGHLY recommend the Hybrid Racing HYB-SCB-01-02 ones. These 2 attach @ the transmission. The cable with the big bushing needs to move in 2 directions (2 axis), therefore, a spherical bushing is the only way to go. Do some research and compare corsport or twm VS hybrid racing bushings. And again, the bigger bushing @ the shifter inside the car is also a 2 axis and that's why I made my own bushing out of a rod end.I'm faster then a prius
