My egr needs to be cleaned. Can i block the vacuum line going to egr valve temporarily until i clean the valve and all the ports. Will this be ok. Will there be any adverse effects? I don't care about cel codes for the time being.
temporarily block egr
you can completely remove EGR with no adverse effects other than a CEL.
Originally posted by Stephen Fry'It's now very common to hear people say, "I'm rather offended by that", as if that gives them certain rights. It's no more than a whine. It has no meaning, it has no purpose, it has no reason to be respected as a phrase. "I'm offended by that." Well, so fucking what?' —Stephen Fry
Why bother blocking the vacuum line? Just leave it until you clean it. if the ports are already clogged they aren't going to get any worse in the next month or two.
But to answer your question, yes you can disconnect the vacuum hose to the EGR valve. Just make sure to plug/crimp the vacuum hose after it has been disconnected.
Originally posted by zedjr10 View PostWhat about the egr valve side of the hose. Do i need to block off that male tip too or just the vacuum hose. I am guessing that side doesn't matter as it needs vacuum to work. So blocked or open is irrelevant? Is this right?
Originally posted by zedjr10 View Postthats not really what i am asking. As i dont want to remove it. I just want to temporarily block the vacuum lines until i can clean the whole system.
