Ok so update on the car, the motor is an H22a, I didn't notice any leaks. It had one hasport mount on the driver side rest are stock. Does have a CEL but didn't have time to jump it. Spark wire plugs were not coated in oil. But I forgot my spark plug puller so I couldn't pull the plugs. The car will turn over sluggishly even when attempting to jump it. The swap was done very well. They said they bought the car 2 years ago and it stopped cranking two weeks ago. I don't think it's the starter because it turns over.
The bad thing I found was there was little to no oil on the dipstick when I dipped it 3 times and the little bit I got looked like it hasn't been changed in a while.
And I didn't check to see if the car had gas in it
I wanted to pull the valve cover but it started to rain heavily and I didn't want any water getting in the motor
So is it worth it to buy it and part it out or take a chance and hope it's the distributor or something with the automatic transmission? Which I know nothing about. If I had my spark plug puller I'm sure it would have told me more what's going on such as if the plug was wet, or had oil on it or if it was igniting. Heck it could be something as simple as a bad coil or igniter
I did notice when I jumped it, I initially saw sparks come off the battery to chassis ground. Not sure if that ground being loose would cause it not to crank over.
If there was plenty of oil on the dipstick and it looked decent, I would have paid for it right then and there. But seeing no oil makes me wonder how long it went without oil and what damage was done internally.
Thoughts?
Thoughts?
