#1 |
Newcomer
Eudm Accord front 5-lug swap
Ok guys, I live in Europe and would like to do a 5-lug swap.
I have been looking at 95-97 Shuttle (same as Odyssey) knuckles but can't find reasonably priced ones. 600€ for a pair is laughable. Same goes for 01-02 Accord V6. I found that the 01-02 eudm 2.3 accord has 5-lug. Does anyone know if the knuckles would fit my '92? If I look around for a while I could maybe find a whole car for that price and use the shortblock and some other parts on my car. I could then sell all parts I don't need. |
#2 |
Wanna be JDM whore
very good question, I would assume the 01-02 eudm 2.3 accord would work. Looks like you might be the first to try.
#3 |
CB7tuner Member
I would bet that the fit or “bolt up” ok. But the axle splining might be the difference.
#4 |
Newcomer
#5 |
CB7tuner Member
Do you have an 01-03 Acura TL/CL there? I swapped the front knuckles off an 03 CL and they worked perfectly. You have to grab the caliper anchor brackets though since the rotors are a bit larger at 11.8" vs. 11.1" and you'll need a minimum of a 16" wheel to clear those brakes.
I paired it up with some Legend GS 2 piston calipers, but using a Wagon caliper, Prelude VTEC or Acura Vigor/3.0CL caliper will work also.
__________________
![]() member's ride thread 93' EX Coupe H22A w/ P2T4 Sir 5spd 191whp 155 wtq 97' Lexus LS400 295k miles.....Luxury Cruiser DD 89' SEi Coupe 42k miles one owner museum find 89' Accord SEi |
#6 |
Contributing Member
When I did my 5 lug swap, from what I remeber I just changed the hubs, rotors and brakes on the stock knuckles. I had rear discs though.
#7 |
CB7tuner Member
The Euro Accord of that gen (CH chassis) shares a lot of commonality with the 99-03 TL and CL. The spindles should fit the CB chassis. I am not sure if the ball joints are different sizes however.
#8 |
Newcomer
@Losiracer2: we have no Acura's over here. Your setup sounds nice though
@gloryaccordy: what hubs did you use? I have rear disc also. @SSMAccord: do you mean the type R? It's just difficult to find parts for a reasonable price here. Not many Honda's where sold here and most will have been scrapped or exported by now. |
#9 |
Contributing Member
You will definitely need new hubs. I'm almost certain I used BB6 Prelude hubs all around.
#10 | |
CB7tuner Member
Quote:
If you search Ebay.co.uk for Honda Accord Uprights or hubs there are knuckles that represent the parts that would fit. At least there are as of the moment that I am typing this. Last edited by SSMAccord; 01-22-2018 at 09:16 PM. |
#11 |
Newcomer
Thx for the replies. I found the type R knuckles on eBay, but we don't know if the balljoints would fit. I would also have to find some calipers and brackets. Would 11.8" rotors work with 16" Wheels? I don't really want to go 17"
Maybe it's easier to buy 4 new bb6 hubs, front bb6 rotors, rear integra rotors, pads and source some used calipers and brackets. |
#12 |
Newcomer
I located Shuttle knuckles, hub, bearing and rotors for 240€. Would 97-01 prelude vtec calipers and brackets work with these?
Still tempted to buy the type R knuckles though. But does anybody know if i can run them with 16" Wheels? |
Thread Tools | |
Display Modes | Rate This Thread |
