Drum Brake Shoes
    Drum Brake Shoes
    Hey Guys,
    I got my drum brakes apart tonight, and the shoes are toast.
    Any recommendations on what kind to get?
    Thanks!
    I'm faster then a prius
    The best you can buy. I think those are usually semi metallic. Part stores only offer one kind 9/10 times so see what you can get.
    Odds are Napa/OReilly/AutoZone ect, have the same 19.99 pads.
    Check your wheel cylinders, and new hardware is never a bad idea.
    Edit: Shoes not pads, sorry.
      The hardware should be required when changing the shoes.
      It is a complete waste of time to change the shoes without changing the hardware. Same thing goes with brake pads. Always change the hardware. Always.
        Do you have any idea how much it would cost to have a shop do it?
          Depends on the shop. And labor hours/part prices.
          Usually I see shops doing around a hundred bucks per side.
            Also, replacing the shoes isn't that hard of a job. It can be time consuming if you haven't done it before.
            Best advice: leave one side together while you take apart the other side and replace the shoes. This way, you can use the untouched side as a reference while putting the new shoes on. I've seen some brake drum jobs take two days because they didn't leave the other side together to reference when they get stuck.
              That's really good advice
                BRAKE: Rear brake drum shoes replacement for most Civic and Accord
                http://www.cb7tuner.com/vbb/showthread.php?t=193923
                  I usually just take a picture after I spray everything down. Good reference imho.
                    I just recently learned that Brembo makes shoes and drums for our cars. Brembo is top quality.
                      But why when you can do a disc conversion?
                      Brembo is good, I agree, but why?
                        Wagner Thermoquiets are one of the best.
                        My work does brake testing for manufacturers and Federal Mogul friction material is the top almost every time.
                        We tested Napa, Duralast, and all the other parts stores brands.
                        You can find them at Orielly auto parts stores
                        member's ride thread
                        91 Accord SE 176k
                          Because not everyone cares to do a disc conversion. Drum brakes actually work just as well in our particular application.
                            how hard is it to do a conversion?*I'd like to in the future!
                              It's really hard.
