Go Back   CB7Tuner Forums > Parts & Performance > Swaps
Old 03-24-2018, 11:17 PM   #1
'93CB7Ex
Gold Member
'93CB7Ex seems to have made some friends!
my k24 swap...
is running good for once. still have a couple things to handle, but it runs good and gets 27 mpg on the highway with only a basemap.
__________________
'93CB7Ex is offline   Reply With Quote
Old 03-25-2018, 12:18 AM   #2
wtfisafleek
CB7tuner Member
This is awesome man! How long did it take you and what more do you have to complete?
__________________
My '91 LX build. Bought September 2017.
http://www.cb7tuner.com/vbb/showthread.php?t=209871
Old 03-25-2018, 08:41 AM   #3
Raf99
Gold Member
Raf99 is very helpful Raf99 is very helpful
How does it feel compared to a H22?
Old 03-25-2018, 11:50 PM   #4
illinois_erik
CB7tuner Member
illinois_erik is very helpful illinois_erik is very helpful illinois_erik is very helpful
thats cool, but i hope you addressed the problematic timing chain tensioner issue before ploppin her in seems to be the largest bane of the K series in that displacement.
https://skunk2.com/engine/support-pa...0-05-0002.html
https://www.hybrid-racing.com/produc...series-engines
__________________
illinois_erik is offline   Reply With Quote
Old 03-26-2018, 09:24 PM   #5
'93CB7Ex
Gold Member
Quote:
thanks! just clean up some wiring, get my ecu fixed, and put the interior back together.
Quote:
right now, my ecu isnt commanding the VTC to work. i ordered another ecu and will have to get the kpro board swapped in. but it drives nice. has a good power band and sounds awesome up top.
nah i just took the stock engine and put it in. mine has around 100k so it will probably need a chain soon anyway.
__________________
Old 03-27-2018, 10:53 AM   #6
Bunta
CB7tuner Member
Bunta is cool... so far.
If I ever manage to blow up my H22 this is the next engine going in, looks to proper in there. I'll bet when you get all of the electrical/ECU issues sorted out it'll be that much more of a blast to drive. Did you have to get a custom header or are there off the shelf options out there for K24 swapped CB7's?
Bunta is offline   Reply With Quote
Old 03-27-2018, 08:04 PM   #7
'93CB7Ex
Gold Member
yea i got my new (used) ecu last night in the mail. i tried 2 different headers before i found this one to work. im running the ktuned budget swap header. clearance in the back near the subframe and intermediate shaft is almost none existent. this works good though.
__________________
Old 03-27-2018, 08:05 PM   #8
illinois_erik
CB7tuner Member
Quote:
Be careful as its oil pressure operated, keep the levels up and run whats on the oil cap, Otherwise itll be new head time from pistons kissing valves
I think there was a TSB for the K24's
https://www-odi.nhtsa.dot.gov/acms/c...41669-6712.pdf
http://www.superstreetonline.com/how...ies-tensioner/
http://techinfo.honda.com/Rjanisis/pubs/SB/B12-042.PDF
__________________
Old 03-27-2018, 08:57 PM   #9
'93CB7Ex
Gold Member
that honda tsb is pretty wild lol. mine is an older tsx (1g). no oil issues other than a cracked valve cover at this time.
__________________
Old 03-28-2018, 11:09 AM   #10
Raf99
Gold Member
I recently learned that the K series in a cb7 hangs low / oil pan hangs low.
Old 03-28-2018, 10:50 PM   #11
'93CB7Ex
Gold Member
mine is kinda low i guess, but my car isnt lowered too much. maybe 1.25/50"
__________________
Old 03-29-2018, 09:39 AM   #12
Rilas
Gold Member
Could you possibly take a picture of how your pan is hanging? Thanks!
__________________
Old 03-29-2018, 09:36 PM   #13
'93CB7Ex
Gold Member
Quote:
yea maybe this weekend.
__________________
Old 04-09-2018, 09:48 AM   #14
BreckAConner
CB7tuner Member
BreckAConner is cool... so far.
What did you do for CV shafts?
BreckAConner is offline   Reply With Quote
Old 04-11-2018, 08:21 PM   #15
'93CB7Ex
Gold Member
i bought some "swap" axles. the passenger side didnt work out. used a 8g civic si ps axle. pretty sure it would perfect on the driver also.
__________________
Old 04-11-2018, 10:57 PM   #16
sonikaccord
Contributing Member
sonikaccord seems to have made some friends!
We should go for A beer run one day
__________________
sonikaccord is offline   Reply With Quote
Old 04-11-2018, 11:07 PM   #17
BreckAConner
CB7tuner Member
Okay, that's good to know. Not sure if I would ever be able to do a K-Swap but if I didn't I was wondering what would work. I've seen aftermarket axles but they are $350 + for a pair.
Old 04-18-2018, 09:20 PM   #18
'93CB7Ex
Gold Member
Quote:
yea i wasnt gonna pay that for axles.
ive been driving the car around for a while now. got my kpro back from upgrading to v4. been trying to tune it some on the street.
also side note: getting the air out of the cooling system is the hardest thing ive had to do with doing the whole swap.
__________________
Old 06-18-2018, 02:59 PM   #19
G. Wiffington
CB7tuner Member
G. Wiffington seems to have made some friends! G. Wiffington seems to have made some friends!
Hey man, I just came across this thread again & I totally forgot about your K Build.
How is the setup going? It looks really good.
G. Wiffington is offline   Reply With Quote
Old 09-28-2018, 10:57 PM   #20
Grumpys93
Contributing Member
Bump. Give us updates!
__________________
~Nick~
