L.E.D's in cluster
    L.E.D's in cluster
    About 6 months ago I installed 5 LED's in my cluster to replace the oem bulbs. Everything has been fine up to 1 week ago. For some reason 3 of them are blinking. One has stopped blinking and doesnt come on anymore. Seems as though it only happens when I put the car in drive. I'm sure the other two will start soon.
    Are they burning out?
    Voltage problem?
    Item Info
    #74 Instrument Panel
    and Gauge LED bulbs
    they are burning out, most likely because they are cheap brand LEDs (most are)
    something that doesnt help is having the heater on, the hot air vents keeps the inside of the dashboard hot which would only shorten their life.
    youve just gota replace them.
      All damn. That was fast.
      Got them from Superbright LEDS
        Voltage prob
        Item Info
        and Gauge LED bulbs
        stick with stock bulbs if you put led ones it looks sick for a day till it fries the cluster and thats what happened with mine. you need to wire resisters in for leds
