4 of July special, my new Cb7
    On Topic: cleaning out EGR ports is fun! Great job on doing that! Did you pull the plugs at all or just spray the crap out of it?
    ~Nick~
      Originally posted by Grumpys93 View Post
      Wow this guy was sneaky! Spam alert!
      No plugs pulled, just tried my best with the cleaner. The CEL didn't go away, but I already knew that was not going to do the trick. It was more of a temporary solution; although, I did saw an increase in mpg, so it did something.
        I smell potential.
        The Lord watches over me!
        "Stop punching down on my people!!!"
        - D. Chappelle
          thats a nice find. good luck with it
          back at it again
            Got a couple of goodies in the mail today. I've been wanting to make this happen for the longest time. Tired of just bolting on cold air intakes on every car I've owned... needed something different.
            Anybody else takes their time opening packages?
            Yep, 70mm!
            Gotta figure out where to place that sticker on the car... #Firstworldproblems
              Any guesses?
              Yes, I am getting rid of the cat aka engine choking device. I thought about selling it, but I'll keep it in case I regret it later on.
              I was really surprised by how nice this test pipe looks. not too bad for just $25 bucks.
              2.5" inlet and outlet diameter
              Just waiting on one more part that's supposedly arriving today. Stay *Tuned* for more
                Update on everything so far...
                got the new ECU in the mail
                ordered a P28, received P06. doesn't matter, still satisfied.
                Beware of emotional moment coming up: details on the chip below. I always wanted to attend a car meet. More so, it was one on my dreams since I started to works on cars, to have 2-step on my car. Street Night Takeover was going to happen in a few weeks a couple of blocks from where I live. That was the main reason I ordered this ecu. Thanks to the cb7tuner community (Moderators on this site may be harsh on you sometimes, but it's always for the better of your CB ) thanks to FaceTuned on eBay for helping me with the tune. I message around 10 or so "tuners" and none of them knew how to do ignition cut on the tune
                side note: An adjustable 3-step is just like a normal 2-step. The only difference is that it can be done at any rpm after the base rpm. My base rpm is 3k, if I hold the throttle at 3k or over, and floor it, it will activate.
                Side by side comparison of the stock tb vs the 70mm.
                [IMG][/IMG]
                Found out that it doesn't fit my manifold. Will have to start looking for an h23 i/m.
                  In the attempt to replace the exhaust manifold gasket, I broke the front bolt and had a big exhaust leak.
                  Ordered this one from Amazon. Not much of an improvement, more of a replacement.
                  Took the stock one off. Time for a little cleaning on the block.
                  Much better now
                  Final result
                  color, a few days later.
                  Note to anyone replacing their manifold with this kind of e/m. Here is the problem and the solution:
                  You have to remove the cat or the downpipe will hit it. the downpipe must be able to move forward and back. Fail to do this step will result in having a leak between the header and the downpipe.
                  Also, the header needs to be bolted to the downpipe first. The order is the header to the downpipe, then bolt it to the head, and finally to the cat.
                  I chased that leak for some minutes and had to take them off a couple of times. Every time I put it back on, the leak persisted, until I did it in that order. So, I'm speaking from experience here.
                  I took some actions to stop the leak but the silicone melted.
                  This gap was the problem.
                  View My Video
                    Nice work That's a pretty clean bay!
                    I have a question. The P06 that you received, was it pre-tuned with the base map and those features that were shown? I am lost when it comes to tuning an ECU. Thanks
                      Wow
                      Nice score!
                        Thank you!
                        There are several sellers on ebay that sell chipped ecu or provide chipping services. You can buy your virgin ecu elsewhere and send it to them so they can chip it. Yes, the one I ordered was pre tuned. They ask you to list the mods that you have done to your car and go from there. The nice thing about it, is that if you ever need another tune, you can just buy another chip (around $30) and swap the one in your ecu.
                          Nice pipe!
                            Wow
                            Nice score! Good thing it's manual, I used to own an automatic Honda Accord and it had the worst fuel consumption. The transmission was also problematic.
                              Big update
                              Unfortunately, this journey will be coming to an end. I just got a good deal on an Acura Rsx (DC5) and since I can't keep both cars, I will be selling my cb
                              If any member here is interested, shoot me a pm. I will be keeping the H23 goodies that I bought for her and I had planned to install, because I know I will definitely be back in the CB game later on
                              PD: Moderators please don't take this post as an ad and delete it. I hope I'm not violating any forum rules. (Feel free to edit it if so)
