cooling fans
    cooling fans
    ok so i have this problem where the cooling fans didnt come on untill the car was in acces mode and i swapped out some of the fuses for the fans and they worked but then stoppeed did this a few more times. i think its the thermistat or something anyone else have this problem cuz its almost summer time and i dont want a blown head gasket.
    Is it blowing the fuses? Did you put the right Amperage fuse back in?
    If its blowing them - theres a short somewhere, or a faulty fan motor.
    My 5.7 LS1 Holden Ute
      Did you check/replace the fan timer under the steering column? If you find you need one, PM me.
      "I'm a dude playing a dude, disguised as another dude"
      "That if thou shalt confess with thy mouth the Lord Jesus, and shalt believe in thine heart that God hath raised him from the dead, thou shalt be saved."
      Romans 10:9
      ><((((º>
        ok i think its fixed now the one thing i thought of but didnt check was the water lolz and it was low i just didt check it cuz i filled it not to long ago and its not leaking? but the temp sencor was reading it all wrong but i got it now
