While at 250,000 I can almost be certain the intermediate shaft bearing needs replaced. I can almost be certain it will not cause a wobble or shake. I have replaced two obliterated ones that where not the culprit.
Have you had an alignment?
It shouldn't be effected intermittently though if not.
Is the intermittent shake related to temperature?
If so I'm sticking with warped hub.
However my g/f has a cd5 that had a wobble. I was sure it was the cv with a bad boot for the last three years(it stays greased). I saw scrubbing on the driver front tire adjusted the tie rod accordingly and bam smooth. Of course you have new tires but what about alignment?
