ok im looking to gather some info ok 1st I have a f22a4 stock with h23 im and intake. second my goals are to have at least 200+whp. lastly my budget is pretty tight right now but once I price everything out ill start saving. so my questions are what is a good cheap reliable turbo kit? would a turbo kit from ebay be good?? also would I have to loose the front mount with any turbo??
thinking about turboing stock f22
http://www.cb7tuner.com/vbb/showthread.php?t=138029 <-mrt
diy whore riiittteeee here
[URL="http://www.cb7tuner.com/vbb/showthread.php?p=2208455"]
http://www.b20vtec.com/forums/members/pr3pg4lyfe.html
would this one be considered a good starter kit?? http://m.ebay.com/Pages/ViewItemPic....462630&emvcc=0http://www.cb7tuner.com/vbb/showthread.php?t=138029 <-mrt
Link didn't work for me. All you gotta do is search man. DSM set-up seems like a perfect starting point for you considering the numbers you want to put down. Budget wise, it should be a good way to go too, just search dsm in the forced induction section to learn everything you need to know, and check this out too:
http://www.cb7tuner.com/vbb/showthread.php?t=17090
1992 Honda Accord Coupe LX
ill tell you one thing right now, stay the fuck away from ebay. lol with that said
heres a cheap setup. source the parts and build.
DSM 14b Turbo
DSM 1st gen or 2nd gen Manifold
Custom Downpipe
Treadstone performance Honda Prelude Intercooler and Piping Kit
Any Bov U want (I used the HKS SSQ Knockoff off ebay and it worked ok)
DSM Stock Turbo Injectors (their 450cc)
H23 Intake Mani
Chipped P06 Computer (out of a 92-95 civic)
Knockoff or True Slowboy racing Turbo J Pipe with a little tube welded in for a hose to your wastegate
Boost, Oil And Wideband Gauges
And i think thats it. If you source good you could end up spending 1500 + cost of tuning.
I made 243 on a stock f22 with f22 intake mani at 12.5 psimiss my turbo cb7
I kinda liked the dsm setup but I don't want to loose my front mount or custom fab 1http://www.cb7tuner.com/vbb/showthread.php?t=138029 <-mrt
Originally posted by pr3pg4lyfe View PostI kinda liked the dsm setup but I don't want to loose my front mount or custom fab 1
Originally posted by nucleara View Postthink he meant motor mount, I made a nice one from scrap at work. but I switched to a diff front cross member so i needed to but turbo clearance was planned into the design. and stock mounts (20 year old) without that front mount sucked a lot.
yeah you gotta stiffen the other mounts or make a new front mount or your P/S pump WILL hit the hood and make annoying dents.
Why threadstone prelude ic kit? Do they fit better
Also to the op, how about makin side mounted intercooler, it will b by your battery.
Stealth ftw.**Blk Housed Slut Crew Member #1**
Originally posted by F20A CB7 View PostWhy threadstone prelude ic kit? Do they fit better
Stealth ftw.
trust me i did this and looking back it was real dumb
Originally posted by quaidum View Posti wouldn't recommend putting the intercooler in the engine bay it needs air going through it not hot air soaking into it
trust me i did this and looking back it was real dumb**Blk Housed Slut Crew Member #1**
http://www.treadstoneperformance.com...0&phot_key=289
Everything you'll ever need in a turbo kit
And only $1800Built & Boosted.
