Old 07-09-2018, 06:07 PM   #1
joey_crandall
Newcomer
joey_crandall is cool... so far.
Wheel rubbing sway bar endlink
It only happens in reverse with the steering locked to the right, doesnt do it on the left side. Car had new control arms, ball joints and outer tie rods. Plus a rotor over hub conversion with 94 prelude vtec breaks and wheels, all parts were new ither than wheels.
I did the ghten everything to spec was thbthebtires on the ground. Car also always seems tonwander tonthe left and wont align into spec on the right side, front and rear
joey_crandall is offline   Reply With Quote
Old 07-09-2018, 06:28 PM   #2
fleetw00d
Contributing Member
Is the picture taken with vertical straight up? Take a photo further back to give us a better overall picture - something looks screwy with the angle of link. Any accident damage (like hitting a curb)?
Quick check: Turn the steering wheel from lock to lock counting the turns, based on that center the steering wheel as best you can for what should be straight ahead, then check to see if the wheels are pointing straight ahead. The right side outer tie rod may be adjusted shorter than the left side tie rod such that the rack isn't centered when the wheel is. If the wheels are pointed a little to the right, to preserve the alignment you have between the front wheels, you can adjust the outer tie rods an equal number of turns, out on the right side, in on left side to correct the relationship between the wheels and the steering wheel/rack.
__________________
90 LX 4dr 5 spd 373,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
93 LX wagon auto 253,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=208490
92 EX coupe auto 171,151 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=205114 RIP
92 EX coupe auto 190,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=210341
LOTS of CB7 parts for sale http://www.cb7tuner.com/vbb/showthread.php?t=192583 or watch for banner ad at upper right
Old 07-09-2018, 07:09 PM   #3
joey_crandall
Newcomer
Best pics i can get right now, wheel doesnt touch when lifted with a jack and its in dirt. I also flipped the link thinking that would help but it didnt
Old 07-09-2018, 07:39 PM   #4
Grumpys93
Contributing Member
What rims are you running? I bet it’s the offset of the rim.
__________________
~Nick~
Old 07-09-2018, 08:44 PM   #5
joey_crandall
Newcomer
95 prelude si wheels with 5mm spacers
Old 07-10-2018, 11:16 AM   #6
fleetw00d
Contributing Member
How much clearance is there on the left side when turned all the way to the left? How many threads are exposed on the inner tie rod on the left side vs. the right?
Old 07-10-2018, 03:02 PM   #7
Crankshaft
CB7tuner Member
Crankshaft is cool... so far.
Send a message via Yahoo to Crankshaft
What is interesting to me is how you say it only rubs when in reverse, check radius rods or something loose that allows the wheel to change angle when in reverse thus allowing it to touch. I think if it was wheel offset it will cause rubbing ALL the time, also did you use the correct end link kit for the car? Go thru everything as we sometimes make mistakes, I once forgot to tighten my lugnuts and got on the freeway to a hellish vibration and thumping sound; glad I didn't kill myself or someone else but this goes to shot that mistakes happen.
__________________
Crankshaft is offline   Reply With Quote
Old 07-10-2018, 05:57 PM   #8
joey_crandall
Newcomer
It didthe same thing before replacing the endlink and radius rod bushings. The link is from autozone, and I just bought the energy suspension universal bushings
Old 07-10-2018, 08:03 PM   #9
Crankshaft
CB7tuner Member
Do you know if the car had previous damage on that side?
__________________
Old 07-12-2018, 12:25 AM   #10
joey_crandall
Newcomer
Not that i know of, it is salvage title due to theft. But ive been under it and havent seen anything out of the ordinary
Old 10-15-2018, 06:12 PM   #11
joey_crandall
Newcomer
Bringing this back from the dead, couldnít figure this out and took it to les schwab today, they told me my rack is off center and my tie rods are adjusted to compensate for this, is this possible seeing how the steering is the same amount of turns from center to left and right.
My right tie rod is adjusted all the way in and the left is adjusted all the way out.
No I havenít been driving the car unless Iím testing
Old 10-15-2018, 07:37 PM   #12
Grumpys93
Contributing Member
Yes that is possible. I would take a look at your inner tie rods and see if the rack n pinion is shifted one way or the other. Was the car ever in a wreck that you know of? If the tie rods are off then that could bring the wheel closer to the sway bar. The amounts of turns to go from one side to the other won’t change either way because the pinion has a pre set movement. What makes the wheel travel more are your tie rods. I would again look at inner and outer tie rods.
__________________
~Nick~
Old 10-15-2018, 09:31 PM   #13
joey_crandall
Newcomer
All tie rod ends are new, the right is adjusted all the way in and the left all the way out, it turns way farther to the right side as well, I actually didnít notice that till the shop said something, on a face book group someone said to center the steering wheel, undo the column to rack joint, adjust the tie rods the same the center the wheels and re connect the column joint... Iíll do this then hopefully itíll be fine and an can get it aligned for the last time,
the car was a theft recovery at one point and the previous owner worked at a junkyard... so who know what was done
Old 10-15-2018, 09:39 PM   #14
djALBINI
Newcomer
djALBINI is cool... so far.
I would try to look at this vehicle while its on a lift or jacked up as high as you can safely go, then check basic lines of symmetry and evenness just to see if anything appears damaged or bent up, frame rails, cross member, etc... That'd be my approach, then go from there
djALBINI is offline   Reply With Quote
Old 10-16-2018, 12:43 AM   #15
joey_crandall
Newcomer
Thatís a good idea, Iíll have to see if my friend can use the shop he works at on a weekend
Old 10-16-2018, 06:04 AM   #16
fleetw00d
Contributing Member
Quote:
Originally Posted by joey_crandall View Post
All tie rod ends are new, the right is adjusted all the way in and the left all the way out, it turns way farther to the right side as well, I actually didn’t notice that till the shop said something, on a face book group someone said to center the steering wheel, undo the column to rack joint, adjust the tie rods the same the center the wheels and re connect the column joint... I’ll do this then hopefully it’ll be fine and an can get it aligned for the last time,
Isn't this what I said back in July; maybe I didn't make myself clear. Check my "Webuilding the Wagon" thread, there is a picture there looking straight up at the ends of the cross member(to which the rack is mounted) checking to make it is also centered under the body structure.
http://www.cb7tuner.com/vbb/showthread.php?t=207733
Old 10-16-2018, 02:11 PM   #17
joey_crandall
Newcomer
I spaced out on what you said, I feel dumb now re-reading it
