INT : P12 Install
    Originally posted by motobmx105 View Post
    i just installed a p12 on my a4 and now im getting an idle surge from 1000 rpm to 1500 rpm. idk should i try and reset the ecu.??
    Why does everyone ask about resetting the ECU? IT WAS OUT OF THE CAR! It doesn't get any more reset than completely out of a car!
    And this is not the thread for your problem, but I'll help; FITV and/or IACV need cleaned/adjusted. Threads in the DIY section!
      i knew that lol but i just cleaned the iacv when i did my h23 IM swap. and it wasnt doin it after that.. just after i installed the p12? idk i think ill ust run the stock one i couldnt really tell a difference.
      http://www.cb7tuner.com/vbb/showthread.php?t=91030 <--MY RIDE!
      http://www.cb7tuner.com/vbb/showthread.php?t=140230 <--MY ongoing ENGINE BUILD!..
        try a different p12. i don't know why someone would even mention the fitv and iacv if they were fine before the ecu swap.
          If your IACV and your FITV are out of whack it will not show much of a difference. Your call, but I think I'd check them both out before I gave up on it.
          Because the different ECU is going to read them differently. The old ECU was used to them being out of adjustment and compensated to some degree.
          When I swapped mine out, I had the same issue; idle fluctuation. I opened them up cleaned them tightened them and it went away. That's why I suggest it.
            idk the fitv is blocked off cuz my TB didnt have one so idk we'll see
              Wait... so you have the h23 IM and you are useing the p12? if I read that correctly you need to be using the ecu for the h23.
                No, he either wants to run the pt6 out of the f22a6, or he needs to delete the secondary butterflies or hook them to vacuum.
                  i deleted the butterflys. i just swapped my stock ecu in and no jumpy idle? i have no clue what it is?
                    I told you what it was. I had the same issue with mine. I swapped in the p12, my idle started fluctuating, I cleaned and adjusted my FITV and IACV again and it was fine.
                      this diy works for an automatic?..because i was about to install mine but for some reason i couldnt take off the plate...did anybody had the same problem...like i was pulling the plate off but on the left side it was like stuck...
                      I MISS MY CB7
                        Did you unplug the harness first? It's pretty tight.
                          no i couldnt is yours auto?...how did you do it?..because i was pulling it and it was stuck...
                          I MISS MY CB7
                            No, mine's a 5 speed, but the ECU harness was tight to remove, which made the plate hard to lift and turn. Carefully use a screwdriver to depress the clip and pop the plugs out of the computers.
                              Yes,it works for autos,i'm auto.Ecu has nothing to do with your transmission,on automatics the tcu deals with that.You'll see it next to your ecu when you install,dont mess with it.
                              spoonsportsaddict
                                ECU and TCU co-comunicate!
                                Only get an MT if you car is MT
                                AT is for AT
                                but AT works for MT aswell
                                Your car wont shift correctly if you dont use an AT ecu
                                Your man for wiring solutions!
                                CB7Man's Coupe H22 Swap
                                CB7Man's Sedan Resurrected From The Dead
