Well as most of you know I am boosting my wagon.
I have about 4 different h23 long blocks lying around.
All have rod knocks or bearing issues, thanks to a crappy h23 crank.
Found out the crank can't handle the high hp due to it having smaller counterweights and not having the slits like the h22 crank.
If it was balanced and all that should be fine, but OEM H23 crank is a no go!
This might also be why oneoffaccord is the only one on the list with an h23, even tho he had bottom end issues as well.
The wagon currently has an f22a1 in it.
I am thinking about just swappin on a good h23 head.
Wondering your thoughts. I have researched and have run a h23 head on
a f22a1 block before, so the technical aspect is not that complicated.
Just wondering your folks thoughts, cause you have taught me everything I know now!
Thanks for your inputs ladies and gents.
