I'm about to do a swap from my stock f22 to a SOHC VTEC f23 I have the stock ecu and its a manual what type of ecu and wiring harness do I need for this swap? Also its a 92 ex
Vtec f23 swap
At least try to answer his question, Joey.
There is no OBD1 F23A1 ECU. You can try a conversion harness and the proper ECU for the engine, or you can get a chipped P28 ECU and have it tuned for your particular setup.
Personally, I feel the F23A1 swap is a major waste of time and money. There's very little to be gained, and SOHC VTEC is more of a fuel economy device than it is a performance feature.
Originally posted by deevergote View PostPersonally, I feel the F23A1 swap is a major waste of time and money. There's very little to be gained, and SOHC VTEC is more of a fuel economy device than it is a performance feature.
While I do not want to discredit you or anyone that has said this in the past, I just cannot agree with this after the extensive r&d I have done with the f22b1. The f22b1 shares the same port pattern and valve angles, and the cylinder head outflows the f22a cylinder head by quite a bit through .5 lift.
A bisi level 2 cam is something like .462 lift if I remember right. Level 3 is something like .486 or something. Don't quote me on that. Its not .5 lift is all I am getting at. There really aren't any off the shelf options for the f22a that have a .5 lift. So, unless people are going to be building engines using top shelf valves/springs/retainers, rev to 10k rpm's and run custom/level x cam's exceeeding .5 lift, the arguement for the f22ax just isn't accurate.
It just isn't. It doesn't respond as well, it doesn't flow as much, it doesn't out perform, nothing. Not until .5 lift has been exceeded, and 99% of people building 4 cylinder engines keep their cam profiles under that benchmark. Sure, the overall potential of the f22a is greater. It really is. But, to achieve that, you are going to have to run a cam that exceeds .5 lift-basically a drag car only. Not a street friendly car by any means.
And all of my research on the f22b1 has come to these conclusions, but the f23a has been proven to outflow the f22b1 and has slightly higher compression. I would consider it a decent candidate for a motor swap.
Just my opinion anyways.Originally posted by wed3kim a douchebag to people and i don't even own a lambo. whats your point? we, douchbags, come in all sorts of shapes and colours.
Originally posted by deevergote View PostAt least try to answer his question, Joey.
I wouldn't mind building an F23A5 based on toycar's argument though.Last edited by Joey GT-R; 11-20-2013, 12:26 PM.'94 JDM H22A: 178whp 146wtq
Originally posted by deevergoteIf you say double dutch rudder, i'm banning you...
I believe the f23 itself is a good motor that should get more credit. I know an f23 you don't wanna race with an h22. A good friend of mine has an f23 with intake, header, exhaust. It pulls, its fast and I like it. It's honestly got to be slower than an h22 as the HP numbers suggest but not by much. It has responded very well to those upgrades though it should, he bought the best available. The thing is its in about the only car it should be in, a 2.3 cl 5 speed.Last edited by cb7 calling; 11-20-2013, 12:44 PM.......father in law has it back again. Time to shine
Originally posted by cb7 calling View PostI believe the f23 itself is a good motor that should get more credit. I know an f23 you don't wanna race with an h22. A good friend of mine has an f23 with intake, header, exhaust. It pulls, its fast and I like it. It's honestly got to be slower than an h22 as the HP numbers suggest but not by much. It has responded very well to those upgrades though it should, he bought the best available. The thing is its in about the only car it should be in, a 2.3 cl 5 speed.
F23As also come in CGs FYI.'94 JDM H22A: 178whp 146wtq
As cb7_calling was saying this is not a worthwhile engine from a performance perspective unless an aftermarket cam and tuning solution is used. Toycar, I really enjoyed your thread on the headflow findings, but those don't account for that head to then be thrown back into an environment that will then only operate on one intake valve per cylinder under a certain rpm and be tuned for economical performance.
The conversion harness is not really an option. Conversion harnesses are designed to allow people to run an OBD1 ECU in a vehicle that came with an OBD2 system. If you have a 2000 Civic EX with a B18C1 you can't tune it with the ECU that's in it so you need the ability to interface a tunable ECU with the car.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
Originally posted by Jarrett View PostAs cb7_calling was saying this is not a worthwhile engine from a performance perspective unless an aftermarket cam and tuning solution is used. Toycar, I really enjoyed your thread on the headflow findings, but those don't account for that head to then be thrown back into an environment that will then only operate on one intake valve per cylinder under a certain rpm and be tuned for economical performance.
Its only on one side, its for economy, blah blah blah.
Yeah well during regular driving the H22, F20c, F20b all only use one valve just the same as any variable valve timing valve train.
So, I dunno. I just don't buy it. The torque curve on the dyno supports the idea that generating pressure in the port is more important than overall flow at lower RPM's, which is why vtec works as well as it does.
Having two valves operational at lower engine speeds allows for too much flow and hurts performance just the same. This is why they evolved to running actuated runners in the manifold towards the end of the f22a's life cycle. The next generation engine they perfected used valve timing instead to accomplish the same thing. Less is more basically at lower engine speeds. They didn't choke the engine by running 1 valve they did it by cutting the flow of the manifold. Same concept, just controlling it with intake management and a butterfly valve instead of valve timing. After enough R&D they figured out the best way to control that flow is with valve timing, not actuated manifold runners.
The million dollar question here;
As technology and engineering has evolved, do they now consider active secondaries or valve timing a more efficient means of controlling flow?
How are current engines designed I guess is what I am asking?
Variable valve timing. And every single engine with variable valve timing has an RPM range that 1 valve is active vs 2. Every one of them.
So, yeah, I just cannot put much stock in that arguement.
no offense or anything, its nothing personal its just that the science doesn't support your theory.
You can hurt performance with too large of a port. All of the import car makers had larger ports in the early 90's and evolved to a different port design by mid decade. Why? performance.
Why does the 2g dsm make more power than the 1g? Port design is smaller, smaller turbo, I mean, WTF is the deal here?
The engine generates pressure faster. Thats all. Yeah, there is an obvious point that too small hurts performance too. I get that. It works both ways though, and thats why I cannot endorse the notion that vtec, variable valve timing or anything of the sort hurts performance specifically because of single valve operation vs dual.
Every car maker has some sort of variable valve timing now. And, they all operate 1 valve before engagement and this practice is leading to much more attractive torque curves and earlier peak torque available as well as higher ve'sLast edited by toycar; 11-20-2013, 02:12 PM.Originally posted by wed3kim a douchebag to people and i don't even own a lambo. whats your point? we, douchbags, come in all sorts of shapes and colours.
Originally posted by toycar View PostWhile I do not want to discredit you or anyone that has said this in the past, I just cannot agree with this after the extensive r&d I have done with the f22b1. The f22b1 shares the same port pattern and valve angles, and the cylinder head outflows the f22a cylinder head by quite a bit through .5 lift.
But if we're going to compare:
At least with an F22A, it's already in the car. There's already a proper ECU for it. No custom mounting, wiring, programming, or plumbing is required to play with an F22A. You're starting with a "free" engine, 10hp less, a bit less torque, and a much less complicated system.
Honestly, the only worthwhile N/A options to me are the H or K swaps. The H22A being the most reasonable, because of the simplicity to install, maintain, and modify.
If turbo is the plan, the F22A can make more power than the average daily driver needs. You can easily surpass the CB7's traction limits on public roads with a turbo F22A... most likely with nothing more than forged pistons (stock sleeves, stock head).
Installing an F23A1 for boost is silly. It offers no real benefit over the F22A, while offering the added complication of VTEC. the extra .1L isn't really significant, and even less so when turbo is involved.
The F23A1 is a perfectly good engine if you have a 6th gen Accord. Absolutely nothing wrong with it. But as a swap in a 4th gen, it's a total pain in the ass for a 10hp gain and half of a proper VTEC system... assuming you can manage to get an ECU to control it effectively.
so could this timing difference be applied to the h22, deleting the iab's, and of course aftermarket engine management.
I remember reading about the better valves angles calculated and employed. So if you were thinking out of the box the f23 seems like a powerful but expen$ive endevor. And at least its not some LEV engine theyre trying to put in
