Old 10-20-2018, 12:45 PM   #161
Fbc 978
Newcomer
Fbc 978 is cool... so far.
Looks like a fun time
Fbc 978 is offline   Reply With Quote
Old 10-23-2018, 05:22 PM   #162
aventari
CB7tuner Member
aventari is cool... so far.
Just did the plenum upgrade.
I used the H23 plenum on the A6 runners, but the H22 and H23 plenums are identical. So you could put an H22 plenum on your A6 runners.
The thing is you have to use the H22 throttle body--which is a good thing as it's bigger. The F22 tbody has a different bolt pattern and won't fit.
So make sure you get a h23 or h22 throttle body (same thing) with the H22 plenum.
aventari is offline   Reply With Quote
