F22 Frankenstein, B16A or H23A?
    Quick question about swapping..
    Would you head swap an F20B DOHC VTEC head onto a F22B1 SOHC VTEC block, or do a complete swap for a B16A or JDM H23A VTEC?
    Thank you.
    its no point in doin a frankstein swap cuz its not going to last long u cant put a b series in a cb7 u better off swapping an h22 and u will be good to go if u want vtec
        This!
        Let me spare deev and all othere members on here the trouble.
        B series won't swap in and if you modified one to swap in it would be under powered for the weight of your accord.
        Franke F series will not be as reliable as you would like it to be. And it requires alot of hassle(IMO).
        H Series Is your best bet. This is what works the best as far as swapping goes. Been done a million times and can be done in a weekend if all parts have been purchased ahead of time.
        You also have the option of Boostin' your F series. Just throwing that idea out there for ya man.
        CB7Tuner Resident Gamer!
        PSN: JDMcb7TX
          Thanks for the ideas.. How well does the F series handle boost (6-10 psi?)? Would I be better off boosting my F22 or swapping the H23A?
            The B16 will pull the Accord just fine. Mind that the CB's on other countries have the F18A Carb with 105 hp.
            However , the extensive work needed to be done in order to properly fit the B series engine is the obstacle. In the end , it is not worth it.
            The overall cost will be more than a H22A swap.
            Just slap in a regular engine that was really meant for an Accord and call it a day. I really don't understand frankie set-up's though.
            1996 Honda Civic LX 2009-2012
            2012 Kia Optima LX 2012-2013
              Look at the Grey/Gray bar on the top part of this forum. Use it also if you haven't already, Read the Stickies! It will help out out immensly!
              It is better to read other Thread and post your question in that thread. You will get a better answer that way then just creating another thread.
              PSN: JDMcb7TX
                H23A Vtec, direct fit. Why fabricate mounts for a less powerful engine?
                1992 Accord Wagon (RETIRED)
                  Do you happen to know what ECU and wiring harness I'll have to grab for the H23A?
                    http://www.cb7tuner.com/vbb/showthread.php?t=159041
                    laid out , for you to play out.
                    A man that keeps looking back can't see whats in front of him.
                      s4l, I suggest that you do your own research. Read through the "swaps" section of this site. You clearly know absolutely nothing about the engines you are asking about, or how they would work with your car. You're being spoon fed bits and pieces of information, and it's only going to confuse you more. Trust me, NOBODY is going to want to take the time to teach you everything that you need to know... especially when it's already written out for you.
                      Go to the Swaps section, read the info on the various engines, installation procedures, etc... Come back with specific questions. Questions that show you've learned enough to possibly understand the answers given to you. Until then, please stop wasting our time. We're not going to think for you. We can't tell you what you want in your car.
                        No worries, I pointed him to look in the swaps section at swapping an OBD-2 H22.
                          6-10 PSI on what turbo? GT42? No. GT28RS? Not for long. T25? Yeah I can definately see more than 10 on a stock F(assuming recently rebuilt). T28? Yeah. 16G? Probably. T3/To4E? Should, reference T25 above. Also are we asuming stock everything else and no intercooler? The amount of pressure vs CFM is also dependent on how free flowing the exhaust is, how cold the air is, and a lot of other factors you seem to be neglecting.
                          Call me Travis.
                          2006 Cobalt LS/SC ~ "Burt the Bloody Bumble Bee"
                          1992 Accord LX ~ "Smoothie"
                          1991 CRX Si ~ Hellion
                          1989 GMC S15 ~ Oldie
                            Are you telling him to put a T25 on his 2.2L engine?
                            Might as well strap a butane torch directly to the head instead.
                              l love these threads...
                              tsx retrofit
                              f22b dohc boosted
                              custom gauges pods
