Is there any pros to runnin a straight exaust with no o2 or cats or res on it if I do decide to run a straight what's a good exaust size for a h22 with headers and intake plus a few extras down the road. Or shoud I fork out the extra bucks and do a full exaust all opions will be taken to thought thank you and god bless
straight exaust or fell exaust
reply
when i bought my first cb7,i'v been using a custom 2.25 straight piping on my f22a6 motor.its a 4-1 header so o2 sensor is on the header and yes you need to run the o2 sensor.your motor depends on it,in order for it to stay alive.lol.. i'v been told before,it'll make your ride sound raspy and loud at high rpm,its best you stay on the safe side too when it comes to loud mufflers.i recommend using a full exhaust piping,i have a greddy exhaust piping just sitting in the garage waiting to be installed and cant wait to hear how it sounds.
Thanks man I have an o2 at the bottom of my header. I don't really mind a raspy sound its kinda like a sleeper you know. But I have a full greddy right know, and it was awsome for like a year but bein slammed it gets a lil tore up but I know you will love your new exaust. But what size do you think I should run and thanks for the input bro
The cat offers very little restriction. There is no need to remove it, and most "high flow" converters offer no additional performance.
Removing the catalytic converter will make your car sound absolutely terrible, it will make your car smell terrible, and it will make your car ILLEGAL.
This thread is filled with lousy information. I'd offer more assistance if I could figure out what the hell the original question was saying...
You need an o2 sensor. You need a cat. The best exhaust size for a mild H22 is 2.5".
lilchase, if you continue to give bad advice on this forum, you will no longer be a member here. We don't need kids removing important components from their cars becuase you don't know what you're talking about.
Originally posted by deevergote View PostYou are an idiot.
EVERYONE NEEDS TO READ AND BE EDUCATED BEFORE YOU POST
For the idiots too lazy to read the whole article:
We have actually tested cat and catless on non-turbo cars as well. If you use a well designed cat there is very little power to be gained by not having a cat. The cat is a place where abrupt angles make a huge difference. Since inside the cat you are making drastic changes going from the diameter of the pipe, into a large diameter area inside the cat, and back to the diameter of the pipe having abrupt angles can really slow things down. This is as true for turbo as it is for non-turbo cars. You also want the gasses spreading out to flow across the complete area of the catalyst bricks of the cat. If the gasses are too concentrated on one part of the cat you will not be able to flow to the full potential of the catalyst bricks. That is why you see the gentle angle at the beginning of the "good" cat rather than at the end of the less optimal "better" cat.Call me Travis.
2006 Cobalt LS/SC ~ "Burt the Bloody Bumble Bee"
1992 Accord LX ~ "Smoothie"
1991 CRX Si ~ Hellion
1989 GMC S15 ~ Oldie
Without an o2 sensor, the ECU will run in closed loop mode at all times.
The exhaust should be 2.5" for a near-stock H22A. 2.25" will work, but it will choke it up top (where the H22 makes its power.)
A catalytic converter (only one on our cars... telling someone to remove their "cats" just shows how truly ignorant you are) is not that much of a restriction, and it is a necessary emissions component.
I believe my 93 had 2 O2 sensore as well.... Well I think it did(up stream-down stream). One was on the header and the other was near the cat. NEVER REMOVE YOUR CAT!!!!
1.) Sounds like crap!!!
2.) It is required for an inspection!!!
3.) It does not increase horespower by much if any!!!
To all ppl agreeing that the cat should be removed.... Are you trying to give the OP bad advice on purpose?
CB7Tuner Resident Gamer!
PSN: JDMcb7TX
