View Poll Results: What should I do about my bumpers?
Leave them black, as they are 38 34.55%
Have them paint-matched to the body, but leave the black moldings all around 52 47.27%
Paint match the bumpers and moldings so the entire car is gray 20 18.18%
Voters: 110. You may not vote on this poll
Thread Tools Rating: Thread Rating: 6 votes, 3.17 average. Display Modes
Old 02-05-2007, 10:56 PM   #1
mndude07
mndude07 seems to have made some friends!
Send a message via AIM to mndude07
mndude07 : 1992 Accord DX
Here's to the fastest slow car I've ever known. RIP
Modifications
Exterior
OEM CD5 Lip
OEM rear spoiler, color matched
35% front, 15% rear window tint
AVS window visors
White LED license plate lights
4300K HID low beams
DIY blackhoused headlights
Smoked amber bumper lenses
Smoked amber corner lenses
Smoked tail lights
Interior
OEM black door handles
OEM Integra clock
OEM black Accord SE dashboard
Black interior door panels
Black rear deck and C-pillars
Black center console
JDM black armrest console
Polished coin tray, ash tray, climate control knob
White LED glove box light
White LED trunk light
Amber gauge cluster conversion
5 speed cluster conversion
Blox torch blue weighted shift knob
Redline goods shift boot, black leather with gray stitching
Sparco corsa pedals
Electronics
Audio
Pioneer 2-Way 5.25" speakers front
Pioneer 2-Way 6.5" speakers rear
Alpine head unit with ipod direct hook-up
Miscellaneous
Battery relocated to trunk
Escort Passport 8500 X50
Suspension/Chassis, Wheels and Brakes
Suspension/Chassis
Neuspeed race springs (485lbs/in front, 300lbs/in rear)
Koni/Neuspeed sport shocks (8041-SP3 series, rebound adjustable)
Ingall's poly camber kit (Eccentric bolts) on front
Progress 22mm rear sway bar with poly bushings and end links
Neuspeed polished front upper tie bar
Megan racing rear lower control arms
Wheels and Tires
Winter: Black powdercoated 9293 EX alloys
195/60-15 BF Goodrich Traction T/A-H
Summer: ???
Brakes
-----Rotor over hub brake conversion-----
>>New OEM CB7 bearings and Acura CL hubs
>>Prelude VTEC rotors 11.1" diameter
>>Prelude VTEC/Accord V6 Calipers, powdercoated wrinkle black
>>Hawkhead carbomet brake pads
>>Goodridge stainless steel brake lines
Stock rear drums
New master cylinder
Powerplant & Drivetrain
Air Induction System
H23 throttle body with 67mm bore by Maxbore
H23 plenum portmatched to throttle body by Maxbore
Blacktrax intake manifold spacer
F22A6 runners
EGR ports drilled & tapped, and pipe plugs put in
Bisimoto heat-shielding intake manifold gasket
All new seals and gaskets on intake manifold
IAB plate removed
Custom 3" intake with AEM dryflow filter
Air boost valve block-off
FTIV block-off
EGR valve block-off
Fuel System
AEM clear annodized billet fuel rail
Exhaust system
Megan Racing stainless steel 4-2-1 header
Megan Racing stainless steel cat-delete pipe
Megan Racing stainless steel type-2 catback
Ignition & Engine Electronics
PT6 ECU
NGK Platinum plugs
Transmission
-----Manual Transmission swap completed on: 08/12/2009-----
M2S4 H23 transmission
F1 Racing Stage 1 Clutch
New clutch master cylinder
New clutch slave cylinder
New left & right axle seals
New drivers side axle
New starter
CorSport USA Aluminum Shifter cable bushings
Stainless steel clutch line
Yeamans17 short shifter
Penzoil Synchromesh gear oil
Cosmetics & Miscellaneous
ESP Auto to 5 speed mount kit in "near chrome" color
Chrome radiator cap
New radiator
Body colored fusebox
Shaved valve cover
Passenger side wire tuck
TAS Auto stainless fender washer kit
r134a A/C conversion
Neuspeed billet oil cap
Spoon sports brake and clutch reservoir sleeves
Charcoal canister deleted
Vacuum box deleted, MAP sensor relocated
MFactory magnetic oil and transmission drain plugs
Upcoming goals
Rear disc swap
5 lug conversion
Finish suspension - well over 1g of cornering ability..no, i'm not crazy
AMR engineering coilovers
Build the f22a
Carbon fiber hood/trunk/fix body
Fix driver side lock - cylinder pins are messed up
More wire tucking/engine bay cleaning
New wheels
Odyssey battery PC680
Re-do interior
Paint matched bumpers & moldings
Stock photos of the car for comparison.
There are no black and white suspension answers!!!!!!!!!!!
mndude07 is offline   Reply With Quote
Old 02-06-2007, 03:03 AM   #2
kidd262
kidd262 is cool... so far.
nice car man...DX version!!
Signature Picture removed due to excessive size
VOLVO 240GL bandit crew....all mighty supertank
kidd262 is offline   Reply With Quote
Old 02-06-2007, 02:29 PM   #3
mndude07
I'm on the other side of the state from Kansas city....I live in a suburb just outside of St. Louis city.
Old 02-28-2007, 07:35 PM   #4
mndude07
bump because I did interior work, got rid of the ricey blue neon, and took some better pics
Old 02-28-2007, 07:39 PM   #5
accordoholic
accordoholic is cool... so far.
HOLY. Thats a clean coupe.
accordoholic is offline   Reply With Quote
Old 02-28-2007, 08:24 PM   #6
stormblkcb7
stormblkcb7 is cool... so far.
Send a message via Yahoo to stormblkcb7
Man this ride is clean I want your door panels now!!!
"click the picture for members thread"
stormblkcb7 is offline   Reply With Quote
Old 02-28-2007, 09:46 PM   #7
mndude07
Thanks for the compliments guys. I know the car is mostly stock right now, but over the summer when I have a job I can really get things done. But i've got a spoiler on the way, just have to get it painted.
Old 03-01-2007, 12:40 PM   #8
accordtypeR
Accord of the Month: August 2008
accordtypeR is cool... so far.
Send a message via MSN to accordtypeR Send a message via Yahoo to accordtypeR
clean looking coupe buddy and its BBB too....sweet !!
My Old Baby
SOLD TO
accordtypeR is offline   Reply With Quote
Old 03-01-2007, 12:52 PM   #9
tommi
Accord of the Month: August 2011
tommi seems to have made some friends!
awesomely clean... youll hafta meet up with yeamans17 before he moves.
(128)Transactions and counting
tommi is offline   Reply With Quote
Old 03-01-2007, 01:12 PM   #10
Mr_Doitagain
Mr_Doitagain is cool... so far.
Send a message via Yahoo to Mr_Doitagain
Always a fan of a clean coupe..... Keep your game face on and look out for the Hate'az
Mr_Doitagain is offline   Reply With Quote
Old 03-01-2007, 01:26 PM   #11
Gemini
AoM:04/07, SE Regional Mod
Gemini seems to have made some friends!
I can say that the cleanest DX i've ever seen, that shit almost look brand spanking new.
1993 Accord LX - Sold
93 BMW 525it - SOLD
92 Accord EX Sedan - SOLD
2000 Accord Coupe - Traded-In
2003 Accord V6 6spd Coupe - Sold
2001 Honda Civic Ex - SOLD
2013 Chevy Traverse LTZ - Kid hauler
2003 Acura Tl 3.2 - Daily Commuter
Gemini is offline   Reply With Quote
Old 03-01-2007, 01:27 PM   #12
babyface
babyface is cool... so far.
very MINTY car... looks great!
babyface is offline   Reply With Quote
Old 03-02-2007, 01:25 AM   #13
fobs
fobs is cool... so far.
looks new.
great ride.
fobs is offline   Reply With Quote
Old 03-02-2007, 03:04 AM   #14
DJ Hizzle
DJ Hizzle is cool... so far.
Send a message via AIM to DJ Hizzle
the interior looks amazing. nice car!
^^^ Please "Like" & Follow!^^^
IG - @WerdWerx
1990 Accord EX Coupe - Click Here
DJ Hizzle is offline   Reply With Quote
Old 03-02-2007, 04:26 AM   #15
Minze
Minze is cool... so far.
Send a message via AIM to Minze
niceee...
1993 Honda Accord LX
2006 Yamaha R6
2004 Acura TSX
Minze is offline   Reply With Quote
Old 03-02-2007, 04:52 AM   #16
erok515
erok515 may have said something they shouldn't have...
Send a message via AIM to erok515
No shit your car is clean as hell.
jdmCITY.com
erok515 is offline   Reply With Quote
Old 03-02-2007, 06:11 AM   #17
oneoffaccord
i cant believe that how clean this is. it looks like it came off the showroom floor yesterday
Old 03-02-2007, 01:03 PM   #18
GREENCB3
GREENCB3 is cool... so far.
Looks really nice you'll be set with a drop and a cd5 front lip.
Project EP hatch on the way
GREENCB3 is offline   Reply With Quote
Old 03-02-2007, 03:35 PM   #19
mndude07
wow thanks everyone, I didn't even think my car was that clean. I dropped off my spoiler today, so in about a week I should have it on the car, i can't wait!
Old 03-06-2007, 10:52 PM   #20
mndude07
Got my spoiler painted and on finally! Ive still gotta make some fine adjustments and wire up the brake light, but you get the idea. (The spoiler was arcadia green when I got it)
I know the car is dirty also, its been raining off and on so much I haven't bothered washing it.
