Closed Thread
Old 02-17-2009, 06:07 AM   #401
all motor
all motor is cool... so far.
could i use these mods on a p12 ecu?if so i need to do something to the intake manifold right? and does it matter if i have a auto?
all motor is offline
Old 02-17-2009, 06:15 AM   #402
visualpoet
visualpoet seems to have made some friends! visualpoet seems to have made some friends!
Send a message via AIM to visualpoet Send a message via MSN to visualpoet Send a message via Yahoo to visualpoet
You can, but the pi2 (as stated very recently) will not activate the secondary butterflies. This means you'll need to hook them up to activate by vacuum (a couple of threads on this out there if you search the site) or remove them completely (also a couple threads) which will cost you some low end torque.
visualpoet is offline
Old 02-17-2009, 06:27 AM   #403
all motor
sweet-thanks alot, i have lookin some of the threads you mentioned but being completely new to the f series and accords i was alil lost
thanks alot guys and cant wait to see what i can do with stock parts(just for fun) before i swap engines and tranny
Old 02-17-2009, 10:54 AM   #404
nappyd420
nappyd420 is cool... so far.
Send a message via AIM to nappyd420
Originally Posted by visualpoet View Post
Yes, in the first post. You want the pt6 ECU from the f22a6. Nothing else activates the secondary butterflies.
In reading why does honda fan use a p06. I know he has some sick shit going on but does that ecu not activate the butterflies.
Leaving the game!
nappyd420 is offline
Old 02-17-2009, 12:36 PM   #405
visualpoet
Ask him. You can use a chipped and tuned p06 and it can activate them, but it's not really necessary for the type of mods this thread discusses, save the money for something else.
Old 02-18-2009, 11:03 PM   #406
Gotz Cb7
Gotz Cb7 may have said something they shouldn't have...
Send a message via AIM to Gotz Cb7
Should add to the sticky, to NOT add the p12 to an f22a6 intake manifold. I know it already says (f22a1 only), but obviously no one sees that part. I did this, and the turn out was...
-Butterflies not touched, plugged into the vacuum as normal. With the p12, it keeps the butterflies closed at all times. Therefore, you have an 8 ported intake system, and you're only using 4 at all times. The gain in the low end wasn't bad, but the 8 ports not opening up in the top-end, you LOSE on your top end.
-Butterflies opened, unplugged the vacuum for the IAB system, which keeps the butterflies OPEN at all times, meaning 8 ports constantly open. You will LOSE your low-end. Your top end will NOT be the best, since the p12 isn't set to give your car the extra fuel in the top end (when the butterflies are supposed to open), meaning...you will NOT feel the extra power after 4700rpms.
I tried everything possible with this p12 on the f22a6 engine, and the only thing you can gain, is low end, but in result of that, you lose your top end. Or, lose your low end, and don't get a gain (a little loss), in top end. I got the ecu for 35 bucks, so it wasn't much of a loss, and it was more like an experiment. I didn't do this hoping for power. People told me "no, no sense in doing it", but for 35 bucks it was worth the experiment. Ended up selling it to a guy at a meet for 55. He seen the gain, because he has a f22a1.
98' Mustang 3V Swap
11' VW CC R36
Gotz Cb7 is offline
Old 02-19-2009, 06:16 AM   #407
deevergote
Don't call me dude.
That's why the P12 isn't part of the original post. It is NOT part of the $500 35hp gain.
deevergote is offline
Old 02-19-2009, 03:04 PM   #408
Gotz Cb7
Yea, everyone hears about the p12, and automatically forgets about the pt6.
98' Mustang 3V Swap
11' VW CC R36
Gotz Cb7 is offline
Old 02-19-2009, 05:14 PM   #409
deevergote
Don't call me dude.
The P12 is for the F22A1 ONLY. Once you use the F22A6 or H23 intake manifold, the PT6 is the way to go.
Old 02-21-2009, 07:33 PM   #410
nauticaboi9486
nauticaboi9486 is cool... so far.
help horsepower numbers help
i have a f22a6 motor that is fresh it has 27000 miles on it i put on new seals and everything is fresh on the motor i was curious of about how much horsepower my car will produce with all my mods. i havent put any of this stuff on yet i have everything but the intake manifold and the throttle body... here is the list of mods
aem cold air intake
ngk plugs and wires
dc header
high flow cat
apexi ws2 exhaust
h23 intake manifold
h22 throttle body bored to the limit
i dont know where i can dyno my car in jersey so i was looking for a rough horsepower estimate. thanks guys
nauticaboi9486 is offline
Old 02-21-2009, 08:43 PM   #411
deevergote
Don't call me dude.
Where in Jersey are you? I know of a few places.
The motor makes 140hp in stock form. Assuming yours is rebuilt, it should be around there. Time, materials, and workmanship can change that slightly.
With the mods... maybe another 20 at the crank? Not a whole lot... especially if you're still running a stock ECU and it's richening it up.
Also, that question would have been better in its own thread (or not asked at all, since nobody can really give you an answer better than your own best guess...) This thread has nothing to do with your F22A6 and its mods.
This thread is about adding power to an F22A1...
Old 02-22-2009, 02:09 PM   #412
visualpoet
Wake up, pay attention, use your head, please.
Originally Posted by nauticaboi9486 View Post
voorhees nj which ecu do you suggest?
Originally Posted by deevergote. View Post
Also, that question would have been better in its own thread ...This thread has nothing to do with your F22A6 and its mods.
Old 02-22-2009, 05:25 PM   #413
deevergote
Don't call me dude.
You'll need a custom tune. A P06 is the cheapest, but the modification and tuning isn't cheap.
That's the last I'm going to say about this in this thread, seeing as it has nothing to do with it.
In fact, I should probably just delete everything in this thread other than the first post...
Old 02-22-2009, 05:55 PM   #414
PR CB7
PR CB7 is cool... so far.
Send a message via MSN to PR CB7
i would say yeah
the fact that peeps dont do these upgrades because they dont have the majical BLACK BOX, or dont know how to make the IAB work,they afraid to use a better ecu, JUST BEACUSE THE IABS
Just do what PR CB7 said.
PR CB7 is offline
Old 02-23-2009, 11:25 PM   #415
chillin943
chillin943 is cool... so far.
Send a message via AIM to chillin943
i've had all 3 motors in my lx. 2 of the stock a1's , 1 a4 , and now have the a6. all backed up by a1 stock 5 speeds. i def had noticable gains in low rpm and high with the a6. its just something about the 4 grand and higher pull that it does. if u can try to find a complete a6 at ur local junk yard it will save the hassel and reep the benifis. i picked up my a6 for 450 with header and down pipe. you'll have to change the o2 sensor location, but thats just a couple wires, so yep $500 or less, 20-30 hp.
chillin943 is offline
Old 03-03-2009, 03:51 PM   #416
deevergote
Don't call me dude.
I'm locking this.
Yes, I know it's a great writeup. I know what I'm talking about. Surprise. You're welcome. I don't need every noob and their mother whoring their post count up by saying so.
I also don't need people PMing me for clarification. Read a little. Believe it or not, I've never actually done any of these things to my own car. I've researched, and helped others do it to theirs. I have provided you with FAR more than I started with myself. Please, I beg you, show a FRACTION of the initiative that my lazy ass has, and do a little learning for yourself!
Closed Thread
