wow thanks alot imao use this on the prelude vtec caliper and rotor swap *~_^
SUS: Rotor/Bearing removal
so yea... yesterday.. i've tried to attempt to swap out my rotors... and needless to say i've only gotten as far as trying to use a ball joint puller on my lower control arm and no good... can anyone give me an insight bout how im supposed to seperate the lower control arm from the knuckle? thankz
So my driver side wheel bearing is def going out. i can hear it rubbing as im driving and doesnt sound good or feel good. Do i absolutely have to take it to a shop to get the bearing pressed out and the new one pressed in? or is there a way to do it at home? les shawb wants like 260 for new bearing, labor and allignment. Too much money that i dont have. But i also need to replace the wheel bearing.
damn. i need to do this asap. i thought you had to buy the hub removal tool, but now that i dont ill have good brakes again and they wont shake like a mo-foMy cb7
h22a
5-spd lsd
Lord, grant me the serenity
to accept the things I cannot change,
the courage to change the things I can,
and the wisdom to hide the bodies
of those people I had to kill because they pissed me off.
