Thread Tools Rating: Thread Rating: 52 votes, 4.71 average. Display Modes
Old 09-05-2020, 10:34 AM   #2741
Grumpys93
Have you tried driving around staying out of boost and seeing if you still get oil in the catch can?
A leak down test will tell you more for sure.
I like that drain setup way easier to drain then mine. Is it just a barbed nippled on the bottom of the catch can to a rubber hose to another barbed fitting to the valve?
~Nick~
Old 09-05-2020, 03:47 PM   #2742
Raf99
If I stay out of boost then less oil yep. & should be noted that I'm hard on the car every time, and it's ran flawlessly at 400HP for 5 years now. This oil issues came suddenly in the past month and has gotten worse.
Bottom of catch can has a threaded nipple, attach hose of any length and valve on the end. Use the AC drain hose clips to hold it in place.
Old 09-05-2020, 07:17 PM   #2743
fleetw00d
Need to figure out a way to have the catch can drain back into the crankcase when you shut the engine down.
Old 09-05-2020, 08:00 PM   #2744
Grumpys93
You could weld in a bung on the back end side of the oil pan and then get a one way ball check valve so that when the engine shuts off and the pressure inside the crank case is 0 the ball check valve opens and allows gravity to drain the oil back into the pan.
~Nick~
Old 09-06-2020, 04:44 AM   #2745
Straight Success
Straight Success is someone to admire Straight Success is someone to admire Straight Success is someone to admire
Where in the engine bay do you have the catch can mounted? I couldn't spot it in the pictures I looked through or the YT videos. I see the drain hose, but not the actual mounting location.
@Grumpys93 had a decent suggestion.
The Lord watches over me!
"...they did the bowties, I did the ascots, as much as I have, I'm still reppin' the have nots..."
- So Raspy
Straight Success is offline   Reply With Quote
Old 09-06-2020, 05:23 PM   #2746
Raf99
yaaa heard / read of people using a drain > back into the pan, but you're also draining the milky crap too unless picked up by a sponge / mesh. + no issues the past 5 years. Plus i want to fix her right, and this could be a broken piston too. I think we are talking about filling the catch can in 500km.
I already booked an appt to get a leak down test performed.
(reservoir and cooler no longer in these spots, but oil catch can is).
