What mods. can be done on a F22A1???
This topic is closed.
    Hey guys, I have a stock 90 honda accord dx and i am looking to do some modifications. I am trying to increase overall engine performance, while keeping it reliable to be an everyday street car. Im definitely looking to make my engine stronger to be able to handle the power it may have. I am looking to do more than just the basics like intake, headers and exhaust. My budget is around $2,500. Any Suggestions????????
    To be honest, to get good quality parts, 2,500 bucks isnt going to get you beyond the basics.
      I know $2,500 isn't going to be enough to get all the parts i need to have my car at top performance but its a start. i want to know what i can do to start off the process, so i can work my way up to how i want my car to perform. Im looking to increase performance and by that i mean top speed and hp but i want to be able to drive it as my everyday car. Any suggestions?
        Is your car a 5 speed? That would be my first priority. If so, how bout you spend that 2500 making your car safer? Get some quality suspension, upgrade your brakes. And if you have any cosmetic damage on the body, see if you can get it touched up. Have a nice clean car and then when it becomes fast it will be appreciated even better.
        '94 JDM H22A: 178whp 146wtq
        If you say double dutch rudder, i'm banning you...
          thanks and well i just recently put in a skunk 2 suspension, would that be considered a good enough suspension to get started with? and yea my accord is a 5 speed. and what do you guys suggest i do for my braking system?
            2500 is a lot
            Bisi cam
            High comp pistons
            H23 IM/TB
            Chipped P28
            That shit is way less than 2500
            Originally posted by lordoja
              Frist, how many miles do u have on your motor?
              92 cb7 http://www.cb7tuner.com/vbb/showthread.php?t=176886
              91 cb9 wagon
                Thanks gloryaccordy! please just elaborate, im kinda new to this... lol and my motor has 250,000 miles
                  By Skunk2 suspension do you mean coilovers and struts? The struts are not the greatest but they will do. Make sure your camber settings are right so your tires don't go bald in a month or two. Have you upgraded your clutch and flywheel? I would recommend Competition Stage 2 Clutch and Flywheel. The lighter rotating mass down there will help in acceleration and your stock clutch assembly can only handle so much extra power. For brakes check out the TASAuto Brake Kits. You don't necessarily have to do the ROH Conversion but adding rear discs to your car is definitely a great addition. There's no reason to be so fast and then you can't even stop that power on a dime. I say this from experience. However these kits do require 15" wheels so make sure you have some that will work.
                    Search for "DSM turbo kit". Best bang for your buck and well under 2,500.
                    My MRT: http://www.cb7tuner.com/vbb/showthread.php?t=200048
                    (Turbo lag - turbo power) + HYPE = VTEC
                    Bought From: Davids92Accord
                    Sold To:
                      So i guess the whole car is stock.Frist i would start with some Bisimoto header and maybe a Bisimoto cam gear.
                      91 cb9 wagon
                        Originally posted by gloryaccordy
                        2500 is a lot
                        Bisi cam
                        High comp pistons
                        H23 IM/TB
                        Chipped P28
                        Bisi Cam Gear - 135
                        Bisi Valvetrain - 369
                        Bisi Cam - 249
                        Bisi Pistons - 459
                        Bisi Rods - 339
                        H23 I/M - 50
                        Chipped P28 - 200
                        Bisi Header - 649+
                        Labor & Tune - 1000+
                        You were saying?
                          Originally posted by Joey GT-R View Post
                          Bisi Cam Gear - 135
                          Bisi Cam - 249
                          Bisi Pistons - 459
                          Bisi Rods - 339
                          H23 I/M - 50
                          Chipped P28 - 200
                          Bisi Header - 649+
                          You were saying?
                          Obv if u add a shit load of parts to my list it will add up
                          But yea
                          H23 IM- 100
                          Bisi Stg 1 Cam (safe on stock valvetrain)- 250
                          Bisi Pistons/Rods - 800
                          Megan Racing header w/3" outlet/exhaust- 500
                          Chipped P28- I bought one for 125
                          Labor + parts - 1000
                          2600
                          And really the pistons + rods aren't necessary... that dude with the black LX coupe was putting down close to 170WHP with a stock block
                          2500 doe... maybe an H23 VTEC on the stock trans w/lower VTEC engagement + JDM H22 cams is the move
                            For starters...http://www.cb7tuner.com/vbb/showthread.php?t=88154
                            After that, skies the limit....
                            N/A or Boost? that is the question.
                            Go fast, stop fast. Don't forget your suspension and brakes.
                            Form.Follows.Function
                              Regardless of what Bisi says, if I cam my motor, I'm beefing up the valvetrain; because it's just not worth it to gamble IMO. And why invest that much money in a motor build to slap a low grade Megan header on? It would probably be a major choke point with those kinds of mods. It just wouldn't make sense.
                              But going back to my previous post. I would rather beef up my suspension and braking to control that kind of power first before I start trying to ramp things up.
