Where can i find 4-2-1 header gaskets??
    Been searching for a few days and have had zero luck/: help please lol
    Follow me on IG to see my builds/pics
    dmfb919
    If you're talking about the ones that go between the manifold halves, this might work for you.
    https://www.autozone.com/emission-co...67575_728962_0
    I've purchased three of them. The first two failed relatively quickly, and the third one was good for the few thousand miles before I parked the car. I don't know if I had a warped flange, or if I had a bad batch for the first two, but it might be worth a try at that price.
    What I would prefer is an OEM gasket from someone that had a crush ring at the circumference of each secondary pipe. There are some Subaru gaskets that are rumored to fit, and it might be worth it to you to go to your parts store and order a few to compare. Couldn't be more than $20-30 to get two or three gaskets on hand to compare.
    https://www.amazon.com/Genuine-Subar.../dp/B00BXLSWCS
      Hell yeah,ill look into it for sure sure. Thanks man,i appreciate the speedy reply lol
      dmfb919
        greddy sells exhaust accessories if you need the manifold to downpipe header gasket.
        https://www.shopgreddy.com/collectio...st-accessories
        member's ride thread
        91 Accord SE 176k
          Felpro exhaust manifold gaskets for like a 95 Subaru. 2 of the bolt holes don't line up exactly but they worked great for me. They do have fire rings on them too.
          1992 Accord Wagon (RETIRED)
            I will toss my vote in for using the Subaru downpipe gasket, used some snipers to cut off the outside edge of the 3 bolt holes in the gasket and it will then line up correctly. I purchased this one off amazon. Its a multi-layer metal gasket style with rings that re-enforce the area were the exhaust gas passes through.
            Its $10 on amazon.
            https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
            Sold too: Grumpys93, '93CB7Ex, Bunta, prodh22accord, SSMAccord, fleetw00d
