$20 says this ends in tears.
Who's swaped a cam them self's?
Originally posted by mchaley$20 says this ends in tears.
Tears of joy. Knowing i did it myself, If i screw something up thats fine with me. It's a learning experience I'm willing to at least try and learn. But really...asinine comments like this don't help anything. Granted it's my fault for posting this in off topic. Fact of the matter is this. It's going to be changed, by me and with my own two hands. Worst case scenario is that i have to learn to change the timing belt in the process. Big whoop.
My plain of attack is as follows (When time and weather permit).
Step 1. Remove drivers side tire. Set engine to TDC.
2. Remove Drivers side motor mount, timing and valve covers.
3. Remove the dizzy. Going to replace the o-ring while i have access
4. Loosen the timing belt a hair with the tensioner.
5. Following the manual, loosen the camshaft bearing cap bolts 1/4 turn at at a time. Starting with the #3 cylinder loosen the two exhaust side camshaft bearing cap bolts. Loosen the bolt on the intake side of the assembly behind the spark plug tube. Repeat for #2 cylinder, #4, #1, and then loosen the cam bearing caps at the end #1 cylinder end of the head behind the cam gear. Finally loosen the 2 bolts at the #4 end that are closest to the distributor...
6. Using the bungee cord to keep a good tension on the timing belt, Slide the belt off the cam gear.
7. Lift out the old cam and replace with new one.
8. Reinstall and tq everything back down to spec.
9. Complete the job with a valve lash adjustment, Double, tipple check my work and fire it up. Guess i should loosen the lash before reinstalling rocker assembly. Job done. Gimme my $20 bucks. If anyone else has some useful information to add please do. Thanks.
Originally posted by d112crzyIt won't end in tears unless he forgets to tighten the tensioner. At worst, he'll be off by a few teeth, which is no biggie. It will run like shit.
Stop being a pussy and replace the timing belt.
Not being a pussy. Just never done it before. I'm sure i can figure it out if i tear into it and get after it. Just rather not if i don't need too. But the marks I'm putting on the timing belt and cam gear should put me spot on. Assuming the belt don't slip on the lower timing gear. But the bungee cord will place enough tension to keep this from happening.
Originally posted by Gettin_faster91Tears of joy. Knowing i did it myself, If i screw something up thats fine with me. It's a learning experience I'm willing to at least try and learn. But really...asinine comments like this don't help anything. Granted it's my fault for posting this in off topic. Fact of the matter is this. It's going to be changed, by me and with my own two hands. Worst case scenario is that i have to learn to change the timing belt in the process. Big whoop.
You forgot spark plug tube seals. Don't be surprised if they leak when you are done.
Also, you DON'T need to make your own marks. Use Hondas. They are much more precise.
