Go Back   CB7Tuner Forums > Parts & Performance > Appearance > Lighting
Old 01-26-2020, 02:29 PM   #21
Grumpys93
Contributing Member
So got the new ballast in and it didn't fix the issue. I checked it everyday for 3 days and today it did it again where driver side does not turn on. Let part to replace will be the igniter.
Are projectors built to either accept HID or LED bulbs? I haven't researched this but I didn't know if led bulbs are different the HID in shape and side.
__________________
~Nick~
Old 01-27-2020, 06:02 AM   #22
Raf99
Gold Member
Umm not sure on the LED light in that housing. This is all starting to point to not enough power getting to the ballast......
Old 01-27-2020, 07:19 AM   #23
Grumpys93
Contributing Member
Not sure how not enough power is getting to ballast. I ran cheap HIDs before no problem. I’m getting 12.8 volts with engine off at the plug and 13.2 with the engine running. So I’m not sure what type of power it is looking for.
__________________
~Nick~
Old 01-27-2020, 10:47 PM   #24
Grumpys93
Contributing Member
So tonight I swapped igniters and the issue didn't follow......But when I swapped bulbs the issue followed. The bulbs were the only things that have no changed position since I first did the retrofit and I have always had issues with the driver side but rarely ever the passenger side. So I tried it 3 different times turn the headlights on to see if it could turn on and it didn't. So I messaged TRS on how to claim the warranty on the bulbs. Hopefully this will close this case and I can trust my headlights working for me.
__________________
~Nick~
Old 01-31-2020, 01:05 PM   #25
Raf99
Gold Member
Quote:
Ya , I assumed you ruled out the bulbs already :P
