Originally posted by h22anow
View Post
INT: honda Prelude steering wheel conversion on 90-91 cb
Originally posted by h22anow View Postall of the 92-93 cbs came with airbags,
I would not mind getting rid of my air bag. I know I would rather hit a fat powdery plastic pillow than metal but I still don't think the air bags were safe untill maybe 2003.
Basicly if you can find the schematic for the horn and cruise control should this work? Along with the 90-91 cb7 plastic cover. Also I have a question what would be the correct way to wire this up so it wont cause a fire?Last edited by 8ball; 12-24-2008, 10:03 PM.
you'd have to get the centering hub (the thing that has no name) for a 9091 so the turn signals would terminate automatically. Also, if you want your SRS light to remain off, wire in a 2 ohm resistor to the car side of the airbag line and the srs module will think the airbag is there, other than that, figure how you want to wire the horn and CC.
those steering wheels look good on 92-93's...
& yeah you can keep the horn/CCLast edited by Night Wolf; 12-25-2008, 11:42 AM.
93 Accord LX Sedan (sold)
Originally posted by Ont1992ADL View PostThis my friend is not true as mine is a 1992 and it has NO air bags lol! so will I be able to change the Prelude wheel to mine?
So this IS possible with 9293s, then??
IS everything pretty much the same or are there different steps?
Originally posted by JarrettIs there a goal you're trying to accomplish besides looking dope as hell?
Boo piss
92-96 Prelude (SRS) steering wheel will NOT fit
I never liked these steering wheels, but they are flooding the board with their simple to intall-ness.
When I went out searching for a new steering wheel I saw one of these in a car, but decided not. It looked to 80's.
Converting to a CD6 Column is easy enough and you can retain SRS with newer steering wheels, the CD6 Column is compatable with many more steering wheels than the CB's, plus the CD is just a CB in disguise, making install a snap.
The CD column can also be re-keyed to fit your CB7 key! The ignition is completly Plug and Play!
The the CG6 (6th gen) uses the same switches as the CB just in disguise!
All you have to do is change the rear of the switch with the CB and your good to go. Some clever wireing (and timer unit from the CG6) the INT wiper works too! Some carefull wireing and the key ring works, cruise and horn also work fine.
Sure it involves some slight dremeling, but its worth it.
I dont mean to whore my work, I just want to see some custom work!
The old 80's lude steering wheel looks dated to me, but being a straigh bolt-on affair. I can see why many people choose it.
Originally posted by accord=inspire? View Posthow do you know if the steering wheel is aligned correctly?
There is also an arrow that points up on the hub adapter...the two "nubs" should be on each side.
The only issue I've had is I cant get it EXACTLY centered...always a tick to the left or the right...not too bad.
pic:
Bought from: TypeG,mak,CB7_ACCORD,ChampCoupe,Blackex
Traded with: Cb7xChun
Sold to: Rob_is_legend,DaddyO,daheavyking
Sedan MR Thread Coupe MR Thread Prelude Si MR Thread
My huge For Sale Thread
A dealer can align the two center
Dont go to a cheapy tire place, their alignments only last long enough for you to drive off the lot.
The steering column and rack can be literally disconnected from each other and set at any point.
However, this can alter the U-Turn radius for whichever direction is changed.
Another common problem with people thinking their steering is off is tire pressure.
idk however as the lude steering wheel may infact be off one tooth just like the S2000sLast edited by CB7Man; 05-26-2009, 04:42 AM.
