abs and non abs axles
    What can happen if i used abs axles if i dont have abs??
    Nothing will happen
    The axles are identical with the exception of the tone ring. its a little toothed ring at the end of the axle for the ABS sensor, it won't interfere with anything if you use it on a non ABS car.
      Originally posted by Tippey764 View Post
      Nothing will happen
      Just want to verify, I ordered a non-abs drivers side axle for my 93 accord MT and received a ABS axle. Do i need to remove the ring? or can I just install it as is? thank you.
      91 Accord LX 5-speed
      93 Accord LX 5-speed
        Install it as is. Most axles these days they just make them all with the ABS ring instead of manufacturing and stocking two different part numbers. The ring just goes for the ride on non-ABS cars.
          I sent pictures of it to raxles and cvj and was told that it definitely is a re-built axle. I am going to return it and look for a virigan OEM axle to re-boot. I am so tempted to go aftermarket, but do not want to end up with a vibrations.
