EXT: Custom LED Side Markers
    you could pissibly recess them and make a lense out of clear resin
      Ya, having a lense fabbed up would look nice...I'd make it an amber lense though. I was actually thinking about using a flat-topped LED instead. Something like this:
      1992 Accord LX - SOLD
        I had thought of this with some sort of clear lense so that when it was off, it would be hard to see. Resin would probably work well. How well do you think resin would hold up to temp changes?
        maroonAccord - is that LED flat or concave?
        Freedom is a road seldom traveled by the multitude.
          The resin would be okay, and those are flat-top LEDs. The concaves would work to though.....
            thats different, madd props
              Thanks, I appreciate that. My parts are on order for the rotor-over-hub conversion.....that ought to be fun.
                wow, that is seriously one of the most awesome ideas i've ever seen for the CB7's.
                i'm highly considering doing it.
                  using a dremel or rubbing the tip of the LED on some fine grit sandpaper turns em into flat tipper's... sand em flat so they are flush with the moulding.
                  i would be doing this if i didnt have s2k sidemarkers...
                    hey man, can you post the ebay link that you got the leds from?
                    thanks.
                      I bought them last year, so I'm not sure what seller I purchased them from but they were:
                      Product Description
                      Emitted Colour : YELLOW
                      Size (mm) : 5mm
                      Lens Colour : Water Clear
                      Peak Wave Length (nm) : 585 ~ 595
                      Forward Voltage (V) : 1.8 ~ 2.2
                      Reverse Current (uA) : <=30
                      Luminous Intensity Typ Iv (mcd) : Average in 5000
                      Life Rating : 100,000 Hours
                      Viewing Angle : 20 ~ 25 Degree
                      Absolute Maximum Ratings (Ta=25°C)
                      Max Power Dissipation : 80mw
                      Max Continuous Forward Current : 30mA
                      Max Peak Forward Current : 75mA
                      Reverse Voltage : 5~6V
                      Lead Soldering Temperature : 240°C (<5Sec)
                      Operating Temperature Range : -25°C ~ +85°C
                      Preservative Temperature Range : -30°C ~ +100°C
                      You can use these to calculate the resistors, and the wiring array:
                      LED series/parallel array wizard
                      LED resistor calulator
                        could always grab them from lsdiodes.com
                          Oh, and sanding them down is actually a really good idea. I neva thought of that.....
                            I just ordered my leds and resistors from lsdiodes.com when i get em in i may have some questions
                              Sure, just PM me....
                                Very cool.
                                I am inspired..
