‘97 CB7 Coupe EX F22b2 IM Help
    First, I recently purchased a ‘92 CB7 Coupe EX with an F22b2 in it. From what I’ve come to find was the f22a intake manifold was somehow retained. I had a throttle body issue so I took it out and cleaned it now I hope to put it back on but Ive ordered a gasket for an f22b2 , id like to know if it would fit. my second question is how can I check what head is on the engine so I can know if they just kept the whole f22a head and slapped it on an f22b2 block. that way I can either get a new intake manifold for the f22b2 head or retain my current setup and get the right gasket to put my throttle body back on. Im also in search for a new MAP so it depends on which TB I end up using. I already pulled one off a f22b1 sohc just to find it wouldt fit. any input is greatly appreciated, if in some way I didnt follow certain guidelines please notify me. Im new to this forum thing as Im 18 and this is only my second car.
    Note* I pulled off an entirr throttle body off an f22b1 just to find it would not fit
      Sounds like the F22A head was definitely used. The intake and exhaust ports are different.
      Look at your exhaust port spacing. 0_0_0_0 = F22A. 0_00_0 = F22B2.
        thanks ! I made sure to get the right tb gasket. now all I gotta do is calibrate my new tps and hope my idle issue is solved
