Go Back   CB7Tuner Forums > Beginner forum -- New members post here! > Beginner "Off Topic"
Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Old 03-09-2015, 06:19 AM   #1
Zombine
Zombine is cool... so far.
Zombine - 1993 Accord EX-I
Hey guys / gals. My names Craig (Zombine), long time member on www.nzhondas.com.
I currently own a DC2 integra which is in the process of a long build.
And a CB7 accord, which is 99% factory. Nearly fully optioned from new, and bought by my grandfather. Only mods at this stage are a nardi wheel, and some sounds to keep me entertained - It's my daily driver.
The CB has an F22Z1, an auto gearbox, leather interior, ABS brakes, the lot. Only thing that wasnt optioned from the factory was the sunroof, as my grandmother had rust issues on her CA accord and they didn't trust them.
After getting bored with the auto gearbox, I decided to swap it to a manual (Which is why I'm here, getting info I need for the swap ), And decided, Why not drop an H22A in at the same time.
Here in NZ we have an abundance of available parts for Hondas, And have collected these bits so far:
Blacktop H22A closed deck shortblock
Complete Euro R head incl cams, intake manifold, TB etc.
Euro R T2W4 Gearbox
Manual H series shift cables
H22A flywheel
And a few other bits and pieces.
As I work at the local Honda dealership as a technician, Getting parts for cheap is not a problem, Have stripped the oil pump I got with the blacktop shortblock, and its perfect, So am reassembling it with all new o rings and seals.
As the car is an auto, from searching here I have come to the conclusion I'll need a CD accord manual gearbox mount, or a BB1/BB4 prelude manual gearbox mount.
What about the rear/front/cambelt side mounts, Will they swap over from the F22 to the H22? Don't want to run aftermarket mounts as I don't want the car rattling :P
Anyway thats enough for now, It's midnight here and I need sleep!
Thanks for reading
Oh and if anyone is interested, Heres a link to the build thread on my integra on nzhondas
https://nzhondas.com/build-threads/9...ears-here.html
Thanks again!
Zombine is offline   Reply With Quote
Old 03-09-2015, 10:45 AM   #2
deevergote
Don't call me dude.
Wow, that thing is incredibly clean! Looks new!
If you want to do the manual transmission conversion properly, you have two options. First is to cut the transmission mount bracket out of a manual CB and weld it in place of your auto mount bracket. That can be a pain, for obvious reasons. Second would be to purchase a conversion mount. I believe Innovative still makes them. ESP (ExplicitSpeedPerformance) used to make them, but they are out of business at the moment (temporarily, we hope.) You may still be able to find a used mount for sale if you look.
The CD or Prelude mounts don't really work properly. They're close, but you still run the risk of damaging an axle.
All other mounts from the CB can be used. You'll find more H22A swap info in the "sticky" threads at the top of the Swaps section of this site.
Old 03-09-2015, 12:20 PM   #3
marcusv8thunder
marcusv8thunder is cool... so far.
That cb is super fresh!
Ive been on that forum before a few times as it has come up in sesrch results.
Hope you get on fine with the H swap. The cars too good for a daily!
UKDM 93 CB3 Page (1) H22A U2Q7 LSD
UKDM 91 4ws Page (3) OEM Minter
NOW H22A U2Q7 SWAPPED
marcusv8thunder is offline   Reply With Quote
Old 03-10-2015, 01:52 AM   #4
Zombine
Thanks guys
I'm sure I'll find all the info I need here for the swap.
Heres some more pics
Blacktop block freshly acid dipped and honed.
Euro R box after I rebuilt it at work and gave it a massive cleanup - Was filthy before hand.
Euro R head after being stripped down and acid dipped, Has had casting marks removed from runners, Valves will be recut and complete head reassembled with new spring LMA's and valve stem seals.
Euro R intake manifold, This has since been stripped down, and has been acid dipped so its sparkling clean inside and out. Planning on getting a Rosko racing IACV adaptor (unless people know these wont fit in the cb?)
The Euro R head when I got it, Filthy!
Nardi wheel the day I installed it (Used to be in my DC2 :P)
Old 03-10-2015, 04:27 AM   #5
JaredLytle
JaredLytle is cool... so far.
Clean cb man, I'm looking forward to seeing where you take this thing!
JaredLytle is offline   Reply With Quote
Old 03-10-2015, 06:21 AM   #6
P_Sean
P_Sean is cool... so far.
Welcome to the Forum!
Clean Integra and CB7. I'm waiting on my Woodgrain Nardi wheel looks dope on a CB7
P_Sean is offline   Reply With Quote
Old 03-19-2015, 02:33 AM   #7
Zombine
Thanks guys
Went to a local place, Where its dead cars, you go around and pick off the parts you want and buy them for dirt cheap. its called pick a part.
Got myself a Prelude shifter unit:
And a CD accord manual gearbox mount, If I have to drill the mount off and move it I'll do that. Don't want to run an aftermarket mount as I want it to look and feel stock. strictly no vibrations.
So now that I have a shifter unit, cables, gearbox, flywheel all sorted, just need a clutch, pedal assemblies, cmc, clutch slave cylinder, and axles I'm thinking of doing the manual conversion now and dropping the h22a in when its built.
So one more question to you fine people, What clutch/brake pedals will work? not sure if relavent as the RHD thing over here. Hoping that BB1/4 prelude work as manual cb accords at these pickaparts is quite hard to come by.
And what axles to run? BB1/4 CD5/6 manual ones all I need?
Thanks
Old 03-19-2015, 02:45 AM   #8
dj_ender
Mod\Dubstep Pusher
I don't think I've ever heard of anyone using a CD shifter in a CB7, it's usually the BB4 shifter.
Old 03-19-2015, 03:24 AM   #9
Zombine
That is a BB1/4 shifter
Old 03-19-2015, 03:40 AM   #10
dj_ender
Mod\Dubstep Pusher
Wow... Totally read that wrong the first time, not sure what I was reading...
Old 03-19-2015, 11:10 AM   #11
deevergote
Don't call me dude.
My friend used a CD shifter. It's nearly identical to the CB shifter.
Using the CD mount isn't the best idea for the conversion. It supposedly works, but it's not correct. It will still cause your axles to be an an odd angle. If you want it to look stock, and you want to do it right, find yourself a CB with a manual transmission, and cut off the transmission mount bracket. Weld it in place of your current auto mount bracket. It's not as easy as simply bolting in a mount, but it's the correct way to do it, and the only way (besides the very non-stock-looking aftermarket mounts) to ensure everything sits as it should. Fortunately, from the look of things, you don't seem to have a problem with doing things the right way
Old 03-19-2015, 11:24 AM   #12
CB7NWDD
CB7NWDD is cool... so far.
Beautiful ride, your family took damn good care of it! Looking forward top seeing that H swap happen
CB7NWDD is offline   Reply With Quote
Old 03-19-2015, 09:49 PM   #13
evil_demon_01
Moderator
evil_demon_01 is someone to admire evil_demon_01 is someone to admire evil_demon_01 is someone to admire evil_demon_01 is someone to admire
Hey Man welcome to the forum.
Car looks clean, what dealership are you working at?
My 5.7 LS1 Holden Ute
evil_demon_01 is offline   Reply With Quote
Old 03-20-2015, 12:56 AM   #14
Zombine
Thanks guys
Working at Waikato Honda.
Old 04-01-2015, 12:53 AM   #15
Grey_cb7
Grey_cb7 is cool... so far.
So clean!
Grey_cb7 is offline   Reply With Quote
Old 04-01-2015, 01:32 AM   #16
Grey_cb7
Is that leather I see?
Old 04-02-2015, 01:56 AM   #17
Zombine
Thanks
Sure is Leather.
Had a few more bits turn up that were ex japan.
Included here is an LMA spring for the euro R head as one had been pinched out of it before I got it, New valve stem seals, All the seals related to the oil pump, Crank seal, front balance shaft seal, dipstick o ring, rear balance shaft plate o ring, Axle seals for the T2W4 box, And theres some more bits floating around too.
Have decided to get an Innovative mounts adaptor mount as the Manual mount bracket is NLA Oh well will make the job alot easier.
I still dont know what axles I'll get away with? Do I HAVE to run CB manual axles and intermediate shaft or can I use BB1/4 or CD5/6 manual axles?
Old 04-02-2015, 07:40 AM   #18
Jarrett
Yes, the CB Accord axles are what you need to run. Why is this a perceived issue?
Old 04-02-2015, 03:17 PM   #19
Zombine
Not an issue, manual CB's are a little bit few and far between here compared to auto ones. I can still get the axles though.
Old 04-02-2015, 08:05 PM   #20
JDMDriver
JDMDriver is cool... so far.
The Accord's condition is Fantastic!! Very original!!
Correct me if I am wrong but your CB seems to be made in NZ when the country still had a car manufacturing industry.
The engine number seems to be for the NZDM.
Noooo, I would have kept her original. More stunning to see a 25 year old car look like a 7 year old car factory fresh in my view, but it is your car and I have always been more an original oem person.
Great choice of mod upgrade though
Rides:
Prelude 91 - AUD - Si - 4ws "Cita Lux Edition" - Bordeaux Red Pearl
Prelude 91 - JDM - Si - 4ws "Si States" - Phoenix Red
CR-X Delsol 92 - JDM - SiR "Transtop" Motegi Edition - Silver
CR-X Delsol 95 - JDM - SiR "Transtop" Daytona Edition - Silver
Accord 92 - JDM - 2.0 Si - "4ws" - Cobalt Blue Pearl
Prelude 91 - AUD - Si - 4ws "Cita" - Cobalt Blue Pearl
Prelude 91 - AUD - Si - 4ws "Cita Lux Edition"- Gun Metal Grey
CR-X 88 - JDM - Si - Black
JDMDriver is offline   Reply With Quote
