The fuel rail from my blown f22a1 doesn't match the bolt up for the f23a. So I was going to just us its fuel rail with f22 injectors because the plugs on the f23 injectors are different. So I got the f22 injectors on the f23 fuel rail but now it seems the injectors are too big. The fuel rail wont sit down thus forth not able to bolt down. Any help is very much appreciated
f22 injectors on f23 fuel rail
Reading the bottom section of this link, it doesn't look very promising if the F22 injectors wont fit the F23 fuel rail.
http://www.cb7tuner.com/vbb/showthread.php?t=5423
Why would you want to use the F23 anyway?
Make sure the intake manifold / lower injector 0 gaskets arent stacking.
if the fuel rail holes are too small for the IM studs then drill them out since there is plenty meat on the fuel rail and the studs cant be that much larger gauge.
pictures would help with the problem you are having cause im not familiar with the f23.
F23 is my only option since I have it and my f22 threw a rod. O gaskests aren't stacked, I checked. The f23 fuel rail has 2 mounting holes as the f22 has 3 and there is absolutely nowhere to drill new holes in f22 rail. I'm not able to post pics idk why.
Edit: they both have 2 mounting holes, sorry. But they still don't match up and I don't see any possibility of drilling new holes.Last edited by jaemil369; 04-10-2012, 03:21 PM.
I found this but it doesn't relate to the F22A.
http://honda-tech.com/showthread.php?t=1955558
Although if the F22A and F22B1 are the same then the F23 rail won't work.
Originally posted by xkjnboix View Postwill the f22 IM fit on the f23?? if so then just use the whole f22 IM with f22 railOriginally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
When y'all are saying "F22" you have to be more specific. While the F22A/H23A1 intake manifold won't work, the F22B1/2/6 will bolt up. Possibly there's a solution for you with an OBD-I manifold from a CD5 Accord. I'm not sure, I'm just helping to brainstorm. If it were me I'd use the F22A head to not worry about that other stuff.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
Originally posted by Jarrett View PostWhen y'all are saying "F22" you have to be more specific. While the F22A/H23A1 intake manifold won't work, the F22B1/2/6 will bolt up. Possibly there's a solution for you with an OBD-I manifold from a CD5 Accord. I'm not sure, I'm just helping to brainstorm. If it were me I'd use the F22A head to not worry about that other stuff.Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
As I stated in my first sentence in first post f22a1, thanks for everyone's input. Reason being I don't want to Frankenstein it, I want the vtec. But the f22b obd1 intake Mani seems as if thars the route I should take to eliminate my problem. Thanks again, and I'm still open to advice and suggestions.
Originally posted by jaemil369 View PostAs I stated in my first sentence in first post f22a1, thanks for everyone's input. Reason being I don't want to Frankenstein it, I want the vtec. But the f22b obd1 intake Mani seems as if thars the route I should take to eliminate my problem. Thanks again, and I'm still open to advice and suggestions.Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
If you want VTEC for performance reasons then you're a little misguided.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
