If this isn't the right forum for this post I apologize. Having a hard time figuring out where to post this.
I am in the process of gathering parts for my H22 swap in my 93 LX. I have read the Swap FAQ and have a couple questions and things I need clarified. As this is my daily driver I need to get this swap done in one day and would like to be 100% certain I have everything right and don't run into any snags. I'm using an OBD-1 H22 with a P13.
1. Is it possible to use a USDM H22 or H23 distributor instead of rewiring the JDM distributor for the external coil?
2. I would also prefer to use an oem exhaust manifold and not an after market header.
-Is the JDM exhaust manifold that comes on the engine the same as a USDM 93-96 Prelude?
-If so can I assume I can use a USDM 93-96 Prelude A-Pipe with it and have it bolt up to my cat/exhaust?
