Old 05-17-2010, 12:44 PM   #1
iamdoby4life
iamdoby4life is cool... so far.
H23 non-vtec swap in 90' Cb7 *HELP ME*
I got a 90' Cb7 and an H23 non-vtec engine i want to put in it but idk what i would need for it to run good in my car. can someone help me with what i would need to make it work please?
E-mail me please with the info if possible.
(iamdoby4life@yahoo.com)
iamdoby4life is offline   Reply With Quote
Old 05-17-2010, 12:56 PM   #2
judonoh
judonoh is cool... so far.
awfully broad question. Alot of the answers are already out there. Here are some of the basics.
Use the CB wire harness
Run a P14 ECU
Everything bolts up
Run wires for/to the IAB
judonoh is offline   Reply With Quote
Old 05-18-2010, 01:02 AM   #3
hovo1788
hovo1788 is cool... so far.
^^^and knock sensor connector d pin 3
hovo1788 is offline   Reply With Quote
Old 05-02-2011, 11:52 AM   #4
nick52
nick52 is cool... so far.
i am doing the same swap in my 91, but i got the h23 harness, does anyone know where i can get a breakdown of the wiring for the 2 cars so i can use the h23 harness and not have to wire any sensors ect in, the 2 main plugs from the ecu to the engine harness are different and i would really rather use the h23 harness since all the wires are the correct length... also what does the little black box next to the prelude ecu control and do I need it on my swsap? any help would make a world of difference, thanks
nick52 is offline   Reply With Quote
cb7 , h23 , swap
