h22a4 valve spring differences
    I am in the process of putting my h22a4 back together and had gotten all the valve springs in on the intake side. While putting the springs in on the exhaust side i noticed they looked different from the other side. Is there a major difference between springs and does it matter what side they get installed in
    Although I don't have experience working on that particular head, generally, the closely wound sides should go against the head.
    A&P-IA
      Check the part numbers. If the part numbers are different between intake and exhaust, then the springs are different... and it matters.
        yea, im pretty sure they are different heights. i know b16 and b18's as well as a lot of the sohc's are different.
        and yes the close wound wire need to go towards the head.
        if the oem springs still have the color on the spring, you can look at a parts catalog and it will show you otherwise youll need to measure the installed spring height.
        this shows as the exhaust being longer which may mean the exhaust may recieve the longer spring. i wish i still had my h22 head so i can help you out.
        http://www.cb7tuner.com/vbb/showthread.php?t=48749
        I <3 G60.
          Thanks Guys. I Had Read On One Of The Forums That The Shape Of The Wire Is Different Between The 2 Sides Lemon Shaped Wire For The Outer Springs Is The Intake And Egg Shaped Is Exhaust. Rather Get As Much Info Before Throwing Head Back On. Thanks Again Appreciate All The Input.
