Have $4k budget. 93 lx 4dr auto right now, swap for sure but which one????
    Here is current state....
      Guys it’s getting to be crunch time for me and I REALLY need help to try and get this swap done this weekend. Or pretty dang close.
      I don’t know where to post this so please admin help.
      Here is my mobile 850 889 6377. If anyone is in/near Pensacola Fl and can help me or know someone that can this weekend if at all possible etc please call or txt me.
      I will continue to look for local shops or help but everyone I call says they don’t touch swaps unless exact replacements etc....
      BTW. This stems from the guy that originally stated he could/would do the job with provided quote, went MIA....
        Current status
        2dr has new distributor but still won’t start. I need help with all the wiring though because it was cut far back so I spliced as much as possible as color for color as I could but nothing. I could use help here too...
        4dr: Hoist is ready and motor is ready for pulling other than axles pulled from transmission which I plan to attempt tonight.
        Other than that, it’s ready to pull.
        I have all the ordered parts and kits for my f20b FINALLY ready for installation.
        Transmission arrived MP1A auto also
        All this means I am ready but need ALOT of help and or guidance etc
          current status
            Guys I found a chip/crack about 3/4 inch long on the inside inner lip of my crank pulley. I went on ebay and just starting browsing for oem used ones and found that they are sole with worse chips cracks than mine??
            Am I o or should I replace? Other than this small crack, this crank pulley looks really good.
              Yeah, I've seen people run some pretty gnarly looking ones. If it was solid metal, it would lead to harmonics because of the imbalance. However, because of the hardened rubber, most of that is mitigated. Can you? Sure. Is it ideal? Probably not. Would a daily driver ever notice it? Probably not.
                Ok thanks man. I decided to run my f22 crank pulley. I am reaching out to grumpy about belt sizing etc.
                  clearly I am past my due date ( to be expected kinda since the help MIA ) but feel confident I am really close. I have alot of pics and updates to add in the next day or so..
                  stay tuned......
                  couple HUGE surprises!!!
                    is there anyone on here running a f20b with an auto tranny?
                    What ECU are you running?
                    Did you convert from OBD2 to OBD1?
                      Holidays and change in plans has this project stalled at the moment.
                      UPDATES!!!
                      4dr Motor out completely. Need clean engine bay and drop f20b back in thats ready
                      2dr . I am trying to get someone local to change the timing belt for me as I am just WAY to busy.....
                        wow has it been WAAAYYYYY to long since I posted about this project.
                        My father-in-law was diagnosed with stage 4 brain cancer in early January this year so MY Entire life has taken the backseat to helping him beat this! He is doing great.
                        Back to this "project". I never wanted to use those words to describe this car but thats whats its turned into.
                        UPDATE!!
                        I have scheduled the drop in of my f20b for early next week. My hope is to be writing in this forum by next Friday 7/26 about how nice and fun it is to have gotten this ride back on the road. I then plan to write a post of what all I bought and installed on this car so far, plus a dyno tune and a HP/Tq sheet for review.
                        I may have a few questions pop up from the install and plan to ask them on this site after researching answers first of course.
                        research first then ask...
                          Car was picked up about 20 mins ago on the way to shop for f20b install.
                          More to come next week.
                            Sorry to hear about your father-in-law. Cancer is a terrible thing.
                            Did the external coil distributor ever come in? What are your plans for the wiring harness? If I were you, I'd have the mangled harness sent to wire-worx or Wirewhere there in Florida and have them replicate something that will plug into your factory shock tower plugs. They can also add a wideband connector, all of your VTEC/IAB wiring, and even change injector plugs if you'd like something better for future mods. Most of their harnesses go all the way back to ECU plugs, but I'm confident they would work with you. That would be the best way of correcting the cut wire issue with the distributor.
                              Thanks for sharing concern for my father-in-law! He is doing better and lives with me now.
                              Also, thanks for asking about the wiring for the 2dr.
                              Update for 2dr: I sold the coupe before moving back to Orlando . I just didnt have the time and effort needed to complete it and bring it with me when I moved. I only have my original 4dr thats in the shop having the f20b dropped in.
                                Gotcha. So your path to a swapped Accord is pretty straightforward now I guess. No more issues like chopped harness or whatever else was a problem when this thread was started?
