Anybody know how to achieve the wrinkle type paint on valve covers?..(I.e. wrinkle red)
valve cover
ya by buyin a can my friend.
any sucessful paint job requires proper prep work, oooooooo yes it does.**Blk Housed Slut Crew Member #1**
make sure you put a self-etching primer on first.
http://www.summitracing.com/parts/VHT-SP204/
later.
Originally posted by TypeG View Postmake sure you put a self-etching primer on first.
later.
Originally posted by Uncle WilleyWhen I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
as far as i know vht is the only co that makes wrinkle and they only make blk and rd you can get vht at advance or autoz. If you do want a different color prime, lay down some blk wrinkle, bake it for 20min at 225, prime again, then coat with desired color
http://www.cb7tuner.com/vbb/showthread.php?t=187851
sold to: cb7rush\h22-accord\Luis\BurtonRiderT6
bought from:jokerxfn-tommi-'93cb7ex
Originally posted by 904drACCORDMANG View Postas far as i know vht is the only co that makes wrinkle and they only make blk and rd you can get vht at advance or autoz. If you do want a different color prime, lay down some blk wrinkle, bake it for 20min at 225, prime again, then coat with desired color
The paint will still be tacky when it gets out, youll want to let it cool for 20-30 min then you should be good to prime and color
correct if you go with red or black you dont even have to bake it the engine heat will cure the paint
you gotta let the wrinkle cure before you add custom color or you wont get the texture
I like the texture that's already on the valve cover.
Member's Ride Thread
Originally posted by mercyboyI'd rather lose by a mile because I built my own car then win by an inch because someone else built it for me..your car is your story, so don't let someone else write the book!
Originally posted by Ander View PostI like the texture that's already on the valve cover.
