How to find exhaust leak?
    I think I have an exhaust leak. Does anyone have any easy tips or tricks to find the leak?
    short
    put the car on jack stands and crawl under with the engine running
      Ok, other than listening, I'm partially deaf in both ears, mostly left side, but I can't hear some tones and sounds play tricks on me, I can never pinpoint noise.
        Run the car when its cold outside. You should be able to see the leak.
        Originally posted by chessboxer
        We know these are good cars, but for some reason, all the world wants are freaking civics and tegs. Bleck.
        Bought From: Slammed4thGen TypeG x2DeevergoteBillKisme
          Jack up the front.
          Make sure it has jack stands and it's safe to the point the car will not fall if you're underneath it.
          Have someone in the car hit the gas. You'll hear the leak.
          Other than that really no way to find it. Have to look/Hear it.
          You will also see holes(Possibly)
          My leak is from my down pipe gasket so you could also rev the car and check around the header/down pipe.
            you may want to take it to an exhaust shop and ask. let them know your situation and they can probably help you out with finding the leak free of charge (i know i would) unless you have them fix it.
              do you have a ebay header?
              COUPE K24
                spray soapy water on the exhaust as its runnin. the leak will make it bubble. works for findin leaks in tires as well.
                  better yet seafoam your car. you should see it then LOL
                  COUPE K24
                    haha you'd have to find it fast otherwise or going to be taken over my smoke.
                    think you're best bet is soapy water and spray on exhaust while its running.
                    the daily: 2001 VW golf 2.0 (tom01golf on local and vw forums)
                    the project: f22a1 400-450whp (build thread to come when things start picking up)
                      you can also look for black sooty areas.
                      I <3 G60.
                        hmm thanks for the input guys, i do have an ebay header but i don't think it's that far ahead. Then again wtf do my ears know. I've heard about the seafoam thing but yea not much time to find the leak that way. I think i'll try the soapy water thing, or take it to a shop.
                        short
                          Wow off topic but... i seafoamed my freinds cb7 and found out he had an exhaust leak at the header to downpipe connection. Wow was that alot of smoke
                          Anyways this method will work sort of lol.
                            ^^ thats where mine is. thats why i asked if he has an ebay exhaust. lol
                            COUPE K24
                              my best friend owns a muffler shop and he uses a stethascope to locate leaks bro . not a bad idea to do. good luck finding it pal.
                              A man that keeps looking back can't see whats in front of him.
