I was wondering about a H23A nonvtec swap. I see hmotorsonline sells a long block for $900. I figured I could reuse my F22A1 5 speed transmission.. it's not perfectly matched to an H23, but I figured it would be ok. From what I have been reading, I can use the stock motor mounts and axles from my car. Correct me if I am wrong.
I have some questions about doing this swap in my '90 LX
1. What clutch and flywheel would use?
2. Can I use a stock H23A1 (I think it's a P14) ECU?
3. I have never used a OBD conversion anything, so what do I need there?
4. Will the Alternator, A/C, P/S and cruise control work with an H23A?
5. The H23A1 uses a manual TB tensioner, yes?
6. I have to reuse the F22A1 fuel rail?
