95 accord ex sedan
Mint grey interior
Charcoal body, with OEM black jams
My h22 expierence went bad so i decided to Build a bad ass sohc vtec for boost.
Motor:
ported and polished head
resurfaced head
three angle vavle grind
New seals and guides
New OEM springs and valves
Turned Crank with new rod and main bearings
New piston rings
Ported intake manifold
H22 throttle body
rc 550cc injectors
MSD sci ignition
UR underdrive pulley
Ebay CAI with bypass vavle
Spoon header
Greddy evo2 catback
Removed P/S, cruise, A/C, and any unnessesscary bullshit under the hood
Fidanza Flywheel
HFP clutch
Suspension:
Tein basic dampers
Basic brembo pads and rotors
New wheel bearings, ball joints, bushings.... all of them
Ingalls front camber kit, hardened washers in the rear
Prelude axles and half shaft
16inch acura cl 2.3 wheels with Kuhmo ecsta 711 tires 205, 50zr 15
Sweet stuff to look at:
Jdm black housings with JDM single bulb corners
Knock off type R grill
EX lip
5% window tint
Pioneer DEH-P6700 head unit with all stock speakers, sounds like a concert
Future plans:
Cam don't know what to get though????????
turbo 10 to 15 lbs of boost
component systems
subs and amps
Tvs up in that bitch
Paint it typeR yellow
JDM fogs
yellow high beams
and as much JDM and EDM shit that i can get!!!!!!!!!!
