sleeves
    It's pretty quiet in here.
    If you don't mind me asking, about how much did that block work cost you?
    YouTube Clicky!!
      well all the machine work cost me 3482.23
      hot tank--65
      install sleeves--800
      surface block---75
      line hone---250
      blue print oil system---100
      custom grind crank----125
      file fit rings----85
      assemble short block---400
      balance assembly---225
      new crank---150+shipping(22)
      all bearings 185.51+shipping(13.47)
      3 angle valve grind--196.95
      bowl hog seats---80
      surface head---45
      .5mm OS valves---160+shipping 12.19
      haz waste---10
      fry cut pistons and re-assemble----180
        I always wondered what each of those things would cost. Machine work seems so exotic to me that I always assume it would all cost an arm and a leg.
          i was expecting it to be a little bit less, say around 2-2.5k... but really nothing was crazy expensive its just a ton of small stuff besides the MID sleeve install
          BTW still looking where to grab coolant from for the turbo if anyone knows
            little update i tested the piston to valve clearance and have probably around 1/4 inch, barely even showed on the play dough i used. so we are good to go on that, going to torque the head down whenever i get back out there(was midnight so time to stop).
              Im curious in case I go like your route. Was that $3482 and then all those parts added or is the $3842 total?
                total, but that doesnt mean thats what your machine shop is going to charge you. it could be less or more, just have to talk to them
                  how big is your cam and he fry cut a forged piston?
                  I <3 G60.
                    bisi stage 1.2 and yes he didnt take very much off though, just enough for clearance for piston to head
                      For your coolant needs bypass your throttle body coolant lines and run them to your turbo. Good looking build. L8r
                      Turbo H23a3 build has begun
                      01-01-2019
                        been doing some work lately and figured id update
                          I believe he meant Fly cut. no such thing as a fry cut unless your at a fast food restaurant.
                          hot tank--65
                          surface block---75
                          line hone---250
                          bowl hog seats---80
                          surface head---45
                          haz waste---10
                          Nice! Lots of unnecessary work though.
                          member ride thread
                          DIVULGE MOTORSPORTS
                          John 10:18 "No one takes it from me, but I lay it down of my own accord. I have authority to lay it down and authority to take it up again. "
                            what was unnecessary on that list?
                              i wouldve started with a cherry crank that only needed a balance and polish or put the money towards knife edging.
                              align hone isnt really necessary unless the block really moved from the new sleeves.
                              seperate price for bowl hog and valve job? i really didnt think the fly cut is necessary, most hondas don't have that much lift or duration. that shop really got you.
                              I <3 G60.
                                line hone because of arp main studs
                                and im guessing it uses a different bit for bowl hogging and doing a valve job? not sure on that one really
                                and fly cut because they stuck out of the block 17 thousands, arias reccomends that the clearance from piston to head is 40 thousands(with head gasket)
