Pinchmyhandle : 1993 Accord SE
    Acura Vigor flush spoiler
    Removed antenna
    New standard headlight assemblies
    Euro clear corner lights
    XenPro HID low beam kit 7000k
    XenPro HID high beam kit 3000k
    G-square grill
    Accord type R badge and nameplate on trunk
    92 Legend coupe front lip
    Clear front turn signals
    Red/Clear tail lights
    Red brake calipers
    Honda OEM sunroof visor
    Speedzone rear visor
    Honda OEM side window visors
    OEM Hood Bra
    86 Accord drivers side mirror
    Honda factory delete passenger mirror
    Windows tinted, 35% on sides, 20% in back.
    ENGINE:
    F22A6
    OBX Stainless header and down pipe
    Removed catalytic converter
    Yonaka cat back system
    NGK V-Power spark plugs
    Focuz triple core 10.2mm plug wires
    Billet oil cap
    Short ram air intake
    K&N air filter
    K&N oil filter
    Magnetic oil drain plug
    Sickspeed plug wire brackets
    Red silicon radiator hoses
    A'pexi radiator cap
    INTERIOR:
    Custom 2 tone design.
    Half original tan leather, half burgundy red cloth
    Acura CL headrests
    delete center brake light
    Custom amp rack
    CB9 trunk storage compartment
    Honda theme steering wheel cover
    Honda theme floor mats
    SUSPENSION/WHEELS:
    15x8 F1R F01's Gold Chrome
    205/50/15 Kumho Ecsta AST tires
    4 wheel drilled and slotted rotors
    Sickspeed 90mm gold spike lug nuts (spikes removed atm)
    ceramic brake pads
    Function and Form Type 1 coilovers
    Front strut tower brace
    AUDIO/ELECTRONICS:
    Gutted OEM clock - installed led voltmeter into it
    Avital 5303L alarm/remote start system
    Kenwood Excelon 6990HD Head Unit
    Kenwood Excelon front speakers
    Kenwood Performance series 12" sub in sealed box
    Earthquake 600w mono amp
    Earthquake 500w 4 channel amp
    Power Acoustics power cap 1.5f
    FUTURE PLANS:
    Body and paint
    The day I bought it, March 14th 2012
    Nice valve cover, clean se.
    2013 Honda Fit Sport Alabaster Silver Metallic GE8
    2013 Accord Sport Modern Steel Metallic CR2
    CB9 http://www.cb7tuner.com/vbb/showthre...hlight=hostile
    CR2 http://www.cb7tuner.com/vbb/showthread.php?t=197787
    GE8 http://www.cb7tuner.com/vbb/showthread.php?t=199289
      Thanks Hostile, nowhere as nice as your CB9 tho!
      The valve cover took me 4 days to do. Sandblasting, primer, paint, and white lettering. On top of that changed the valve cover gasket and upper and lower seals.
        very clean se and a great platform to start with
        what shall not
        kill you shall
        only make you
        STRONGER
          Thanks Vegascoupe!
            VERY nice start man!
              Thank you very much cb7_with_snail!
                Where did u get those plug wires?
                  I ordered them on Ebay. They are really nice quality, and look good too.
                    Nice clean engine bay man! SE FTW
                    BB6->http://cb7tuner.com/vbb/showthread.php?t=200445<Summer Lover
                    BD6->http://cb7tuner.com/vbb/showthread.php?t=194262<Dailey/Future AutoX
                    Mazda 6s->http://cb7tuner.com/vbb/showthread.php?t=201313<Wifes
                    CB7->http://cb7tuner.com/vbb/showthread.php?t=189108<Sold
                      Thank you AAPOQ!
                        New tie rod ends installed last night. The old ones were seriously SHOT!
                          Got my Avital 5303L alarm/remote start setup installed today. Still want to get the power window module for it, but that can be added later.
                            After a lot of long and hard pros and cons, I've decided to ditch the after market front bumper I bought, and get an aggressive lip instead. I really like the Greddy 94-95 accord lip.
                            Guess we will see what I can find.
                              Just a little spring...eeerrrr...winter cleaning. When I was changing the tie rod ends, I noticed the rust buildup on the new rotors.
                              So I took some leftover brake caliper paint, and did a little touch up to the rotors. Here is the front.
                              And here is the back.
