Old 12-05-2009, 04:44 AM   #1
speedyfreak86
speedyfreak86 is cool... so far.
5 lug and disk conversion ?????
Is it possible to go to a all around disk and five lug? I've found conversions for five lug and for 4 lug disc. I just wanna know if its it's possible and how hard it is. If i should even do it, I mean I could just do one or the other annd if I decide to do that which one should I go with?
speedyfreak86 is offline   Reply With Quote
Old 12-05-2009, 05:52 AM   #2
GunRunner
GunRunner seems to have made some friends!
I believe you have to get the rear disc conversion before you can do the 5 lug swap. The hub on the rear disc is the part that is changed.
read carefully: http://www.cb7tuner.com/vbb/showthre...light=lug+rear
-1993 Accord EX SOLD
-2012 GMC Canyon V8 4x4
GunRunner is offline   Reply With Quote
Old 12-05-2009, 08:08 AM   #3
jimy
jimy is cool... so far.
Sure you can. I just finished my 5lug swap. My car was a dx with rear drums. Swaped in rear disk from an se then the corresponding parts to make it 5 lug. Be ready to pay lots to convert.
It actually cost more then I thought it would. Lots of new parts were added.
Used odyssey front knuckles
used odyssey front calipers
new front slotted/drilled rotors
new odyssey brakes pads
new lower ball joints
used 93 se disk knuckles
new se calipers
new pads
new prelude hubs
new type r slotted/drilled rotors
new rear brake lines
new misc bolts, screws, and washers
new Tein basic coils
98 type r gun metal wheels
Here are the pics.
my old setup with drums. I was lowered with kyb agx and intrax springs.
I had to buy a rear disk setup so I replaced the whole rear assembly so I could get a rear swaybar. The calipers on the setup was shot so I ended up buying two new rear calipers.
my old setup
How it sits now
what I paid to get it done.
Used odyssey front knuckles $150 for the pair
used odyssey front calipers $100 for the pair
new front slotted/drilled rotors $100
new odyssey brakes pads $30
new lower ball joints $60
used 93 se disk knuckles $175 (really $325, paid a member on here $150 and never received them. Still haven't seen my refund or the knuckles. Needed rear disk so had to buy another set.)
new se calipers $275
new pads $25
new prelude hubs $150
new type r slotted/drilled rotors $100
new rear brake lines $45
new misc bolts, screws, and washers $100 all oem from Honda
98 type r gun metal wheels $450
1760=$17 take or minus a few dollars
Just be ready and know what your getting into. Depending on what you need to replace or don't use will be less.
jimy is offline   Reply With Quote
Old 12-05-2009, 08:12 AM   #4
GunRunner
wow, what a change. how much better does the car stop now?
Old 12-05-2009, 08:15 AM   #5
jimy
I had just finish the swap and had only drove the car around the block a few times to see if it was running right then it went into storage. Will find out when I fully break in the rotors in the summer.
Old 12-05-2009, 08:19 AM   #6
GunRunner
damn, just saw MN after I read your post.
Old 12-06-2009, 08:25 PM   #7
browneyes
browneyes is cool... so far.
Send a message via MSN to browneyes
look nice... good job... good motivation right there..
new se calipers
new pads
new prelude hubs
Here are the pics.
my old setup
How it sits now
new pads $25
browneyes is offline   Reply With Quote
Old 12-07-2009, 09:44 AM   #8
willsocal83
willsocal83 is cool... so far.
whatever u do try and stay 4 lug
willsocal83 is offline   Reply With Quote
4 lug , 5 lug , conversion
