Old 01-28-2010, 04:28 PM   #1
pr3pg4lyfe
pr3pg4lyfe is cool... so far.
Send a message via AIM to pr3pg4lyfe
Exclamation cluster blinks slow
ok so I had a previous problem cluster turned on randomly nd when I steped on the brake. I found out under the dash a cupple wires burnt. I wrote down what wires go where. I cut them nd rewired them. now every now and then when my lights(cluster) is on it randomly blinks. any1 have a idea why this is happening 2 me. I checked the fuses some dumbass put a 30A fuse for the blinkers when it's suppose to be 10. I put the 10 in it's not blinking the the beat of the music just randomly.
http://www.cb7tuner.com/vbb/showthread.php?t=138029 <-mrt
diy whore riiittteeee here
[url="http://www.cb7tuner.com/vbb/showthread.php?p=2208455"]
http://www.b20vtec.com/forums/members/pr3pg4lyfe.html
pr3pg4lyfe is offline   Reply With Quote
Old 01-28-2010, 04:34 PM   #2
NWaccord
NWaccord is cool... so far.
Are all your light in good working order? Maybe the flasher relay?
NWaccord is offline   Reply With Quote
Old 01-28-2010, 04:40 PM   #3
pr3pg4lyfe
where is that located?? I have some type of relay in my hand. it has 5 prongs but only 4 connectors connect to it. 2 are goldish color and the other 3 are coppered color. and the color of the relay is black is that it?? it's not connected it was jus hanging there by black tape. it's weird nd getting on my nerves
Old 01-28-2010, 04:47 PM   #4
NWaccord
The turn signal/hazard relay is by the driver's left foot. There's a little side wall panel on the left side under the dashboard - that's the fuse panel. The turn signal flasher is above the fuse panel farthest to the left above the big square box. The turn signal flasher is about 1-1/8" wide by 7/8"tall and 1-1/2" deep. It's hard to get out with all the other parts around it and you have to spread out the little side clips on each side of the flasher relay to release it. Make sure you have a light - it's hard to see under there even in the day time.
Old 01-28-2010, 04:49 PM   #5
pr3pg4lyfe
yea all my lights are working fine. there's no light out. I have the door open night lights on just the cluster blinking like a retart.
Old 01-28-2010, 04:51 PM   #6
pr3pg4lyfe
nope not the flasher in my hand. there's only 5 wires going to this relay.
Old 01-28-2010, 04:55 PM   #7
NWaccord
Im not sure where that one does, I know witch one ur talking bout though
Old 01-28-2010, 08:21 PM   #8
pr3pg4lyfe
dont know either. i no that the wires i had cut, when they were cut, the lights didnt go on. no hazards nuthing. once i put new wires in and connected them the way they were everything was back to normal. except the blinking slow and i didnt connect that relay still worked connected it to the relay nuthing changed??
Old 02-02-2010, 05:07 PM   #9
digitalightkenz
digitalightkenz is cool... so far.
you might want to take it to an electric guy. But they charge you by the hour. good luck
digitalightkenz is offline   Reply With Quote
blinking , cluster , problem
