Old 04-13-2010, 11:00 PM   #1
dark3630
dark3630 is cool... so far.
Gas Gauge Movement
My gas gauge moves around a LOT, is this a common problem? I did a search and could only find threads with peoples gas gauges not working. Mine works, but say I start it, it will say that it's almost empty, and then I get down the road and I'm at a 1/4th of a tank, then later I look again and it's almost at the red line again.
It's really annoying at times because I don't know how low I am Also, is there a way to test the "Low Gas" light to see if it works?
dark3630 is offline   Reply With Quote
Old 04-13-2010, 11:10 PM   #2
agol
agol is cool... so far.
Send a message via AIM to agol
your sensor in your tank is obviousy messed up lol, and youll know if you dont have gas the bulbs going out on the dash like never happens
agol is offline   Reply With Quote
Old 04-13-2010, 11:12 PM   #3
TypeG
Moderator
TypeG is very helpful TypeG is very helpful
fuel sending unit. it's resistance can be tested with an ohmmeter. look for instructions in a repair manual. later.
Avoiding dirt at all costs
TypeG is offline   Reply With Quote
Old 04-14-2010, 10:25 AM   #4
dark3630
Ok, I wasn't sure, in the threads I searched a few people said their bulbs didn't work.
Thanks! I'll check that out then
gas , gas gauge , guage , movement , problem
