Old 05-17-2010, 09:56 PM   #1
No Name13
No Name13 is cool... so far.
fuel gauge is a liar!
i drive a 91 ex and ever since the car was given to me i noticed a problem...the fuel gauge wasn't accurate! at times it will say that i have 1/2 a talk, 10 minutes later it will say 1/4 tank..and sometimes it will even say i have 1/8! then it will go back up to a quarter..well you get the point.. the question is how do i fix it without going aftermarket?
No Name13 is offline   Reply With Quote
Old 05-17-2010, 10:17 PM   #2
TypeG
Moderator
TypeG is very helpful TypeG is very helpful
fuel sending unit.
test it with an ohmmeter. you can access from a panel that's under the rear seat.
get a haynes manual for the instructions on the full procedure. later.
Avoiding dirt at all costs
TypeG is offline   Reply With Quote
Old 05-17-2010, 10:23 PM   #3
No Name13
thanks. i always knew i should have gotten one allot sooner.
Old 05-18-2010, 01:26 PM   #4
bcjammerx
bcjammerx seems to have made some friends!
Send a message via AIM to bcjammerx Send a message via Yahoo to bcjammerx
couple things just FYI
our tanks are square...so 1/2 tank isn't really 1/2...also, you'll notice that after 1/2 your fuel level will drop off faster than pre 1/2 level...cause of that.
when the car leans forward (going down hill) your gauge will show less fuel than actual
when the car leans backward (uphill) your gauge will show having more fuel.
That is normal...acceleration will also make the gauge go up...and stopping will make it show low. I notice this all the time. So only worry when it is outside that realm of normalcy
____
bcjammerx is offline   Reply With Quote
Old 05-18-2010, 01:37 PM   #5
H22Artman
H22Artman is cool... so far.
its normal to fluctuate.
dont worry too much unless you fill up and it read less than full. then you know there is a problem with the sending unit.
if i have a half-tank in the car and i do some hard accelerating, it can drop by as much as a quarter-tank. after the car comes to rest it levels off and goes back to where it should be.
Bought from: Bisimoto, FuncOvrForm, HondaGuy1212, wed3k, Konigstiger, 1st2run, BillKisme, k-mart, benjerman112
H22Artman is offline   Reply With Quote
fuel , fuel gauge , gauge , problem
