Old 02-16-2018, 11:19 PM   #41
92smokeaccord
92smokeaccord seems to have made some friends! 92smokeaccord seems to have made some friends!
Well put the butch as close to the ground as I could. Upper arms hit the shock towers so that痴 the limit. Lol changed rims to ex coupe rims. I think she looks good
my new turbo build
92smokeaccord is offline   Reply With Quote
Old 02-16-2018, 11:32 PM   #42
NH-503P-3
NH-503P-3 is cool... so far.
The car looks way good. EX wheels are always a good choice.
Old 02-21-2018, 03:58 PM   #43
92smokeaccord
And new wheels! Not sure who they are made from but 15x8 0 offset gonna get some flairs!
my new turbo build
Old 02-21-2018, 06:47 PM   #44
Raf99
Why is there a grinder in the picture ?
Old 02-21-2018, 09:14 PM   #45
92smokeaccord
Calipers needed slight shave..maybe 1/16 inch.
my new turbo build
Old 02-26-2018, 08:28 PM   #46
92smokeaccord
Went to strip some parts off my parts car today. Lighting was nice so I took some pics
my new turbo build
Old 02-27-2018, 01:16 AM   #47
Mike1357
Mike1357 is cool... so far.
Looks aggressive. Definitely need some flares though. The turbo setup does indeed look stock and I love that you kept all the accessories. The numbers sound really good. Makes me want to pick up another car for DSM things.
Mike1357 is offline   Reply With Quote
Old 02-27-2018, 10:28 PM   #48
92smokeaccord
Well. I can稚 seem to stop getting deals thrown at me so i scoop them up!!
TEIN Coilovers! Got these for 40$ yes 4-0 doll hairs! Not in bad shape maybe year or 2. Going in tomorrow
my new turbo build
Old 03-20-2018, 02:35 PM   #49
92smokeaccord
Oh yeah went to j yard today for a lock actuater and ended up with these for 15$.
my new turbo build
Old 03-20-2018, 02:44 PM   #50
NH-503P-3
Damn those are some good scores. Those tail lights would have been triple that in a Cali pap.
~Mark~
Old 03-20-2018, 04:22 PM   #51
Raf99
Do you know what model of Tein's they are?
Old 03-20-2018, 07:02 PM   #52
92smokeaccord
Basics. But 40$ I知 not complaining They ride pretty good but the are to soft and require a lot of travel which makes my running problem even worse. I知 gonna try a frankinstine set up. Gonna take the coil springs off the tiens and use them with some Koni yellow and some eBay sleeves.
my new turbo build
Old 03-20-2018, 10:39 PM   #53
Mike1357
Awesome yard finds!
Old 03-21-2018, 07:14 PM   #54
Raf99
Can't beat the price! So i have Tein Super Streets. And they are too soft too. Most the web says it's the spring and not the shock. some have swapped it out for a stiffer spring but most (like me) just put up with it. And technically it's the UCA ramming off the body that only bothers me.
Old 03-21-2018, 07:25 PM   #55
HenRoc
Black Thunder
HenRoc seems to have made some friends! HenRoc seems to have made some friends!
Send a message via AIM to HenRoc
I'll see you on Sunday.
Henry R
Koni/Neuspeed
1992 Accord LX R.I.P
1993 Accord EX OG since 'o3
Legend FSM
HenRoc is offline   Reply With Quote
Old 04-13-2018, 06:36 PM   #56
92smokeaccord
Well. Update I suppose. Lol. Got the bitch tuned!!!!!!! Blew it up day after whooooooa!!! Yeah ended up hurting cylinder 3. The spark plug wire was chaffing on the valve cover and shorted out lost spark for second and it ended up firing to late and boom! I知 pretty sure it痴 a ringland so I知 gonna pull thing apart and change the piston out maybe more. Gonna do compression test and see what I知 at. I知 gonna gap the rings out farther to help with the expansion
my new turbo build
Old 04-18-2018, 12:00 AM   #57
92smokeaccord
Ok so today I decided to rebuild the motor due to cylinder 3 only having 60 psi on the compression test. Here is what I found. After ripping into this motor I found that only cylinder 3 has extensive damage. Eaither way I replaced all 4 pistons /rings. From the looks of things I may have had a misfire at some point on cylinder 3 making the chamber extremely hot and causing the rings to expand to far and but each other. So in the end she broke a ring land as well as the second ring. As of now she is about half way to being completely rebuilt. All I have left is to put the head and timing which will only take me a couple hours. Heres some pics to show the damaged goods vs the new clean rebuild. Also gapped the living hell out these rings so this has way less chance of happening again.
Broke piston ringland literally just fell out along with ring
Broke ring
New/ used pistons from junk yard. No chips or cracks loose pins.
New pistons in the block
That’s pretty much it till tomorrow. Gonna finish her up nice so I can finally drive my car again. Next step is some tires!
my new turbo build
Old 04-18-2018, 12:10 AM   #58
Jarrett
If you ever get a wild hair to go pull pistons out of a car in the junkyard again, the G25A uses 85mm pistons and I'd be willing to bet that it uses a 30.55mm compression height, too. The Vigor has a 9.0:1 compression ratio and the 2.5TL is 9.6:1. All that with an 86.4mm stroke. So that done in a 95mm stroke application should be well North of 10.5:1. If you were looking for a cheap boost on low-end power.
Old 04-18-2018, 05:45 PM   #59
92smokeaccord
Dude you kick ass! Question tho. Can I use the rods out of the g series too or am I gonna have to swap rods? I can稚 reallt find much info on the g series motors. Would be so nice I知 sure the ringlands are thicker too
my new turbo build
Old 04-19-2018, 01:21 PM   #60
Jarrett
I would doubt it. But if those pistons are 30.5mm compression height, like I would bet they are, then you don't need new rods. If they use a floating pin, which the available year models would suggest they didn't, then you would just order aftermarket rods anyway.
EDIT* It seems that the G25A uses a 138mm rod, as opposed to the 141.5mm rod in the F22A. No good for this engine.
