My tranny is leaking transmission fluid and power steering fluid simultaneously. I changed the hoses, both axle retainers... I thought the leak was a bad gasket (the one around the converter on the bell) but above the tranny is dry and starts getting soaked under the place where the hoses are attached and the liquid runs to the axle and the gasket, so, it isn't the gasket.
when I park and turns off the car starts the leak, then stops after a few minutes. Is there a part that you replace and the problem ends or I have to unmount the tranny to reach downthere? I cant see where start the leak because the mount, and why 2 fluids mixed at a time?
Thanks.
Thanks.
